Old 03-17-2023, 11:50 AM   #121
Default Re: Dimmer switch + gauge lights not working
I won't be disappointed if you find it works satisfactorily "as-is" and we go on with life. I was merely pointing out that it may be easy to fix, and offering to help you do so.
Old 03-18-2023, 02:59 PM   #122
StarLady
StarLady is just really niceStarLady is just really niceStarLady is just really niceStarLady is just really nice
StarLady's Avatar
1992 SC
I understand, and I sincerely appreciate the kind offer. But you have spent so much time and effort on this already. Thank you
1992 SC - TwinCam (Automagic)
Bought it brand new, and still loving it today.
StarLady is offline   Reply With Quote
Old 03-18-2023, 03:03 PM   #123
StarLady
StarLady's Avatar
1992 SC
Busy day yesterday.
I wrapped the connector in electrical tape and left it lying on the floor. Then snapped the switch into its home. After cleaning under the console, I put back almost everything I had removed. I'll wait a couple of days to secure the console at its base in case I need to get in there again.
The lights seem to be working okay -- gauges and PRND lights are on, and the dimmer dims and brightens as it should. I haven't gone anywhere yet to test under actual running conditions.
I again want to thank you all for helping me get my Satty through this.
Old 03-18-2023, 03:45 PM   #124
dtuuri
dtuuri is a name known to alldtuuri is a name known to alldtuuri is a name known to alldtuuri is a name known to alldtuuri is a name known to alldtuuri is a name known to all
1991 SC
You aren't that far from an actual repair at this point in time. Just a bad connection on pin C or a drop of solder or a new diode and it would be like new. Putting it back together, leaving it stuck in performance mode from now on, seems like a hollow victory. Just sayin'.
dtuuri is offline   Reply With Quote
Old 03-19-2023, 01:07 AM   #125
StarLady
StarLady's Avatar
1992 SC
I know what you're saying, but I have to pick my battles.
As long as my gauges are lit up, and the current state of the Perf switch doesn't negatively affect my Satty's driveability, it will have to stay that way.
My next issue to take care is my power windows that are getting stuck. I might start a new thread if it gets complicated.
Old 03-19-2023, 09:59 AM   #126
dtuuri
1991 SC
In view of all that, once you have your windows in the up position, pull the 30a window fuse in the under-hood fuse box and use your air conditioning from now on.
Old 03-19-2023, 06:45 PM   #127
StarLady
StarLady's Avatar
1992 SC
Haha.
Nah... I need the windows to be operational.
Old 03-19-2023, 08:14 PM   #128
Waiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to behold
Haha.
It's a bit of a project.
http://www.saturnfans.com/forums/sho...234273&page=12
Besides replacing the motor and greasing everything, there were broken tabs and disintegrated door sound material.
dimmer switch for dash lights- wiring diagram RKelly5327 S-Series Tech 4 09-05-2018 09:19 AM
Dash lights not working. Dimmer Switch? ScentsyDiva Vue General 11 04-30-2014 12:53 PM
Dash dimmer & Lights on chime not working! Critter S-Series Tech 8 07-06-2011 03:25 PM
Dimmer Relay Buzzing? Dimmer Switch? HELP!? bhoard L-Series Tech 9 03-11-2010 10:45 PM
L200 2002 Dimmer gauge / switch mnkdrt L-Series General 2 07-29-2004 01:54 PM
