Old 10-27-2004, 09:09 PM   #1
auger
auger is on a distinguished road
Question issues swapping '92 Power Steering pump for '99?
Car is a '92 SL1 206,487kms, leaking noisey pump, have found a '99 SL1 pump at a wrecker's, is this a suitable subject for a straight swap?
auger is offline
Old 10-27-2004, 09:25 PM   #2
geartooth94
geartooth94's Avatar
Default
only way to tell is to get your old P/S pump bracket off the car and line up the holes on the new pump to see if they match.
Kinda a pain, I know!
geartooth94 is offline
Old 10-27-2004, 09:54 PM   #3
auger
Default
Thanks for the reply 94SL2withphone, I was afraid that might be the only way to tell.
I've been getting by for years using additives to slow the leak, and have recently started using a new one, I can't for the life of me think of the name, they make oil additives also, comes in a big white bottle....
Anyway, I figured I'd just have done with it and swap the pump, but maybe I'm making more work for myself than I should?
auger is offline
Old 10-27-2004, 09:54 PM   #4
Default
Should bolt in no problem. As far as I know the pumps did not change at all for bolting in or hose hook up.
ssicarman is offline
Old 10-27-2004, 10:02 PM   #5
auger
Default
Bless you ssicarman! That is just what I needed to hear right now.
This is the original pump in the '92, I figure the hose connections will be frozen pretty good by now, and maybe I should start shooting some sort of lube on them now and for the next couple of days to try and loosen them up?
I also found a post on this that suggested the rubber mallet shock treatment on the wrench, rather than constant pressure applied which might break the hose connections or round them off, does this sound like a plan?
auger is offline
Old 10-27-2004, 10:46 PM   #6
LATEMODELRACING
LATEMODELRACING is on a distinguished road
Default
the only other issue is a evo or non evo pump.
LATEMODELRACING is offline
Old 10-28-2004, 12:51 AM   #7
sierrap615
sierrap615's Avatar
Default
i beleave the pulley size changed in 96. the larger one will have less drag on the engine
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 10-28-2004, 12:18 PM   #8
auger
Default
Now there is the rub, this '99 is a non EVO pump, my '92 SL1 has EVO.
Thanks for the help guys, I guess I could try to replace the seal in my old pump.
auger is offline
Old 10-29-2004, 01:22 AM   #9
amazinghl
Default
All SOHC cars has NON-EVO or manual steering.
00 Insight 72mpg
amazinghl is offline
Old 10-29-2004, 04:11 PM   #10
auger
Default
After '95 Saturn dropped EVO from SOHC cars.
auger is offline
Power Steering pump going Ls1Junky S-Series Tech 7 04-09-2008 10:56 PM
Power Steering Pump riggs S-Series Tech 0 01-07-2007 09:35 PM
Need quick help - replacing power steering pump and water pump on V6Ö. Emanresu2 L-Series General 6 05-18-2006 05:38 PM
Really need the Power Steering pump??? alleninpa S-Series General 3 09-07-2004 01:54 PM
L Power Steering Pump spork Miscellaneous Tech 12 01-07-2002 04:02 PM
