Old 02-11-2013, 11:20 AM   #1
strawberripocky
strawberripocky is on a distinguished road
strawberripocky's Avatar
1999 SC1
Default High mileage, transmission slam, ever annoying coolant light... the end??
Well I've gotta say I haven't been here in quite some time! Hope everyone is doing well!
Down to business! I'm about to reach 225k on my little beast, and I'm really not expecting much more than that... I've begun thinking about what kind of car I'm going to get next (right now it's looking like Mazda 3 hatchback or the Hyundai Veloster... opinions?) but I know nothing could ever come close to my Saturn, so the decision is difficult.
Anywho, my transmission has been slipping for a few months now, it's increasingly getting worse, as this morning I was pulling into work and I hit the gas and nothing happened... until I tapped the brake pedal and then the gas again. When I switch it into park, it idles at about 2,000 rpm. My service engine light goes on and off periodically, so I'm not sure what's triggering that. And my low coolant light has been flashing for a few minutes after I start up the car - the coolant level is down but it's hard to tell where it's coming from with the wet weather we've been having.
A little bit of history:
I had the transmission rebuilt about 3 years ago in April due to the reverse slam issue, and over the past few years I've replaced a LOT of things that should prevent a coolant leak, ie. the water pump, hoses, radiator, etc.
I'm really horrible with keeping up maintenance on it in the cold months. I REALLY hate the cold. I'll admit I have neglected it lately, but mostly because my life has become busy and some really silly things on it have been breaking lately (ie. the passenger seatbelt guide ), but is there anything I can do for a low cost that can get me another year or so out of her? Thanks
1999 SC1 "Oracle" - a little handicapped, but still gets around :P
227k
Plastic > Rust
Add to strawberripocky's Reputation
Rate the quality of this post and help strawberripocky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
strawberripocky is offline   Reply With Quote
Old 02-11-2013, 11:48 AM   #2
brags
brags will become famous soon enoughbrags will become famous soon enough
1996 SL1
Default Re: High mileage, transmission slam, ever annoying coolant light... the end??
Well the coolant Leak could be coming from anywhere and not necesarily
from the radiater wich everyone thinks could be, you mentioned rad hoses and water pump were replaced at one time well could be something as simple
as a Loose clamp on a hose or replacing a hose or a gasket seal of some sort
somewhere else, make sure You dont run the coolant Low what ever You do, You mentioned the
transmission - (Could be a Big ticket item for repairing)
but You had it repaired rebuilt before did the shop give You any warranty?
and have You checked the transmission oil Level?
Not sure if your buying new or pre-owned but out of the 2 i would pick
mazda but the hyundai might have a better warranty worth looking into
i have 2 vehicles that im very happy with Next one might just be another
Nissan Product.
1- 2007 Nissan Murano
2- 1996 Saturn SL1
" Any man that doesen"t share his knowledge in cars is wrong to do !"
Add to brags's Reputation
Rate the quality of this post and help brags reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brags is offline   Reply With Quote
Old 02-11-2013, 12:28 PM   #3
strawberripocky
1999 SC1
Definitely could be a loose clamp, it's a slow leak so I'll check that first. It most definitely should not be the radiator, as I have replaced that within the last two years, but I know parts can be defective too. As for the transmission warranty, I'm pretty sure it's way past that, so I feel there's not much use digging that up. Also I know that a transmission rebuild is not *exactly* what it sounds like, in that they only "rebuild" what's causing the problem, which in this case, was a reverse slam... I'm assuming slippage in drive is a whole different issue. I'll also check the transmission fluid.
Also, at this point if it's something that can't be temporarily fixed without shelling out a lot of money, I'm going to have to say goodbye to the Saturn and put that money into a new car. Also speaking of which, I would like to buy pre-owned, so that's why I'm kind of leaning towards the Mazda. Hyundai just started making Velosters in 2011 I believe, so it's really too new for me to get a decent deal on a used one at this point.
227k
Plastic > Rust
Old 02-11-2013, 02:19 PM   #4
TXSaturn02
TXSaturn02's Avatar
Looks like we think alike. I purchased the 3 hatchback in October (just had the first oil change). It is a 2013 with skyactic engine. The MPG is similar to the 2002 SL2. The only thing that concerns me is the Advanced Key Entry (key is bulky and expensive to replace), but if you don't lose your key - no issues. There is also an option to disable the key feature so that you don't need the fancy one, but I plan to keep that feature as long as the vehicle is less than 5 years or so old.
I decided to avoid Hyundai because they lied about their MPG and confessed some time in November (I saw too many complaints, with Hyundai MPG, and went with Mazda). I kept my SL2 and drive it most of the time, but have no issues to complain about with the Mazda - yet. Although, I know that dents (metal) will be an issue, unlike the SL2.
I'm still hoping the MPG will improve once broken in - time will tell.
As of 07/25/18: 51,495 Miles
Old 02-12-2013, 07:07 AM   #5
cityhawk
cityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to behold
cityhawk's Avatar
1993 SW2
I had a persistent slow coolant leak around the lower radiator hose on the passenger side. I finally slathered the nipple on the engine side with some RTV and tightened down the hose and no more leak.
+1 on seeing if your trans work is warranteed.
Saturns:
1993 SW2 MT 201,000 hard Boston city miles ("Rozzie")
Gone but not forgotten:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
1928 Ford Model A Tudor Sedan
Add to cityhawk's Reputation
Old 02-12-2013, 11:08 AM   #6
adam22
adam22 is a jewel in the roughadam22 is a jewel in the roughadam22 is a jewel in the rough
2006 VUE 2.2L
Lucas Trans Fix can sometimes give you some more life.
Add to adam22's Reputation
Rate the quality of this post and help adam22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adam22 is offline   Reply With Quote
Old 03-13-2013, 03:47 PM   #7
strawberripocky
1999 SC1
I know it's been a month since I've even been near this post, but I did check my warranty and it was a 1 year/unlimited miles... I got the transmission rebuilt 3 years ago in April. Correct me if I'm wrong, but I am thinking it could possibly be the clutch, since when I give it some gas, the RPMs shoot up and the car drags. I have the receipt for the transmission work but it does not give me a list on what was actually replaced... would they replace the clutch if it looked worn or is the clutch something that would affect the reverse issue I was having also back when that was fixed? Forgive my ignorance!! Now 2 days in a row on my way to work, the engine cut out when I went to give it gas from being stopped at a light (in the most inconvenient places both times, might I add!). The fuel pump has never been replaced, so that could be it, but I'm hoping IAC just needs to be cleaned... eh!!! I can kinda deal with the transmission acting wonky and jerking me around, but not being able to move at a green light in South Jersey during morning rush hour is just plain dangerous!
227k
Plastic > Rust
Old 03-14-2013, 10:06 AM   #8
That's weird.... when you say, "nothing happened," you mean the engine rpms revved up, but car did not move?
Most parts stores will read the code for free, should be a letter and four numbers, like "P0123" - have them read it, write down the number, but don't buy anything, and post back what it is. Even if the light is off, it is usually stored and can be read. Have them check your battery and alternator if they do free checks as well, as the transmission is electrically operated and can be sensitive
Has the fuel filter ever been changed? How did the transmission fluid level check go?
I'm sure they would have been happy to replace parts at your expense if they saw something worn. Sounds like you have two separate things going on at the same time (well, three if we iinclude the coolant leak), engine stalling and transmission not engaging.
Old 03-20-2013, 10:42 AM   #9
strawberripocky
1999 SC1
Exactly! So, I guess something did happen since the the rpms revved... silly me. Car wouldn't go anywhere until I tapped the brake then gas (which probably isn't necessary, I'd likely just have to take my foot off the gas and put it back down again).
I've got the codes read at Autozone many times, it's just a matter of me getting my lazy butt there to do it, and cold weather makes me even less willing to go out. I'll try to get there asap and get it done though. Also, I did not know that the code can be stored even if the light is off!!
Ever since I've had my car (since 85k miles in '05), I don't remember the fuel filter being changed. Is it a small job? I guess I should also mention my mileage hasn't been fantastic either, which you've probably figured already. I've been getting about 25 mpg on a good week. Transmission fluid level looks good. The engine actually hasn't stalled since I mentioned it, thank goodness, though I know the problem causing the stall wouldn't just go away. Could the transmission issues come from a bad alternator? I know I've never had the alternator replaced, and it seems it's an affordable fix if I could do the job myself.
227k
Plastic > Rust
Old 03-21-2013, 12:07 AM   #10
silv01
silv01 is on a distinguished road
+1 on the fuel filter. My '01 was acting up and never did figure out what was going on until I replaced it. Yeah, it was fairly easy and the car is happy....for now
Add to silv01's Reputation
Rate the quality of this post and help silv01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silv01 is offline   Reply With Quote
'98 SC2 - High Engine Coolant Temp and Low Coolant Level Warning Light mystic54 S-Series Tech 3 01-17-2013 09:29 PM
High Engine Coolant Light Quala67 S-Series Tech 12 08-05-2011 09:16 AM
high coolant/transaxle fluid light? bdobraj S-Series General 5 12-17-2010 04:26 PM
Coolant light is flashing.. 97 Saturn SL2 approx 128k mileage m3rcury S-Series Tech 5 03-19-2007 04:48 PM
2001 SL2 - High Idle in Park only & Low Coolant light JMR S-Series Tech 6 02-16-2006 08:24 AM
