Old 01-21-2012, 11:57 AM   #1
tiggrdj
tiggrdj is on a distinguished road
2001 SL2
Default 17" wheel & tires "SLOW"
Hello All
I have seen on a number of posts that people are stating that they have removed their 17" wheel & tire packages because they were "slow". I would like some feedback on just what would cause the 17" to make a car slower if the overall tire diameter remains the same as stock but with a lower profile. I suppose if the overall weight of the wheel/tire package was substantially heavier it would result in a higher rolling weight but that is the only reason I can think of for slowing the vehicle down. Your thoughts??
Add to tiggrdj's Reputation
Rate the quality of this post and help tiggrdj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tiggrdj is offline   Reply With Quote
Old 01-21-2012, 12:26 PM   #2
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
Default Re: 17" wheel & tires "SLOW"
Using a wheel/tire combo that results in having a larger over all radius/diameter than a stock setup has the same effect as gearing up the car. Acceleration is reduced if you're starting in 2nd gear as opposed to first. The same applies with larger wheels.
That's just the torquing aspect. Larger wheel and tire combos are heavier as well which would reduce acceleration as well
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is online now   Reply With Quote
Old 01-21-2012, 01:04 PM   #3
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
If a 17" wheel/tire package has the same overall diameter as a 15" wheel/tire package the 17" package will be slower- even if they weigh the same weight. It has everything to the moment of inertia. The 17" package has a higher moment of inertia (moment of inertia is the tendency to resist motion). And as a result, the 17" package won't slow down as easily once it is moving.
This is of course nominal. There could be instances where a 15" package could have a higher moment of inertia than the 17"- but it's unlikely.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 01-21-2012, 01:19 PM   #4
Montreal300
Montreal300 has a spectacular aura aboutMontreal300 has a spectacular aura about
Montreal300's Avatar
2002 SL1
Given an equal overall diameter over the tires. A 17" wheel combination weighs more than a 15" combination. Steel or castings are just heavier than rubber. The moment of inertia is higher as wheels get larger in diameter. Check out the serious drag racers in any class. Everyone runs the smallest wheel possible.
2002 SL1 (55,000 km @ 11/12/2016)
2006 Chrysler 300C (modified)
2012 Hyundai Santa Fe
1999 Jeep Grand Cherokee
Add to Montreal300's Reputation
Rate the quality of this post and help Montreal300 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Montreal300 is offline   Reply With Quote
Old 01-21-2012, 04:26 PM   #5
Blacktree
Blacktree will become famous soon enough
What the guys above are hinting at is that with a larger wheel, the outer rim is further from the center of the wheel. For example, with a 14" wheel, the outer rim would be 7" from the center of the wheel. But with a 17" wheel, the outer rim is 8.5" away from the center of the wheel.
And the further the outer rim is from the center, the more rotational inertia it has (i.e. takes more force to speed it up or slow it down). This is true, even if the larger wheel has exactly the same overall weight and overall wheel diameter (including the tire) as the stock one.
Add to Blacktree's Reputation
Rate the quality of this post and help Blacktree reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Blacktree is offline   Reply With Quote
Old 01-24-2012, 10:13 PM   #6
S3aturnR
S3aturnR's Avatar
1999 SL1
Originally Posted by tiggrdj View Post
Hello All
i have no idea what, exactly, makes the 17" wheels slow. i DO know that i was able to prove that it was slow. repeatedly. in every autocross i entered. until i went back to 15" wheels. went from mid-pack finishes to a 3+year unbroken podium streak. undefeated locally. a combined total of 5 regional championships.
i stopped asking myself "why" a long time ago. i also decided that i'd go to a 13" wheel if i ever got the cash and opportunity to do so. i'm convinced it would go even faster...
s3aturnr
Add to S3aturnR's Reputation
Old 01-25-2012, 02:51 AM   #7
93SC2'in
93SC2'in is on a distinguished road
93SC2'in's Avatar
1993 SC2
of course you dont want to auto x with 17's but on a DD they are fine i've ran mine for about 2 years now with no problems i don't think my car is slow or hard to stop i went directly from 15" sawtooths on bfg g-force sports to 17"s on the same exact tire and it was night and day the 17"s felt a lot better smoother ride and better grip. if you plan to race your car then stick with the 15"s or if looks are important and you dont want it too heavy go in the middle and get 16"s
93 SC2, 5-speed, <dead and gone>
95 SL2 5-speed, oem header, gsi TB, sprint 2.0, kyb gr2's, wb02, SAFCII, CAI, 17"s
Speed Kills - save lives, Drive a honda
Add to 93SC2'in's Reputation
Rate the quality of this post and help 93SC2'in reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
93SC2'in is offline   Reply With Quote
Old 02-07-2012, 04:52 PM   #8
HStockSolo
HStockSolo is on a distinguished road
HStockSolo's Avatar
It is mainly wheel and tire width that is beneficial. I have 17x9s with 245/40s for the front. I already had the tires, and I needed winter tires for cold weather compound. Other than Star Specs most of the warm weather tires suck at low temperatures. I am pretty sure these UHP winters will clobber the Star Specs.
245/40s on 17x9s verses 225/50s on 16x8.
225/50R15 V710 on left--skinnier than 225/50R16s on right?
There isn't a lot of wide tires in 15" or 16" wheel diameters anymore. There certainly isn't anything wide in UHP winter tires in those diameters.
It is pretty certain that 255/40R17s are faster than 225/50R16s on at least some cars. I ran my 205/50R15s and 205/50R16s on my 325i last year, and found that car to considerably slower than my SC2 on the same tires. I'll be running those 225/50s on it this year mainly due to class limits and budget.
1995 Saturn SC2 - ST(X)ish
1994 BMW 325i Sport
www.furrin.org
Add to HStockSolo's Reputation
Rate the quality of this post and help HStockSolo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HStockSolo is offline   Reply With Quote
ABS kicking in at slow speeds intermittently while "gently" stopping the car cityhawk L-Series Tech 15 08-06-2015 08:30 PM
Vin "7" Vin "8" Vin "9" brake pads/rotors universal? demoncamber S-Series Tech 4 09-09-2009 12:35 PM
Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door???? Token S-Series General 21 09-08-2005 10:14 PM
Consumer Reports:"VUE AWD system was slow to engage." Heavy Mettle Vue General 54 04-05-2002 10:54 PM
Consumer Reports:&quot;VUE,AWD system was slow to engage.&quot; Heavy Mettle Vue General 0 03-31-2002 12:15 PM
