Old 05-17-2018, 12:38 PM   #1
Zeebins
Zeebins is a jewel in the roughZeebins is a jewel in the roughZeebins is a jewel in the rough
Zeebins's Avatar
Default How do I get the front bumper cover off
So eariler this morning I was going to replace my bumper cover with a new one I bought a while back but when I went to remove the 3 bolts near the tire, one of the heads snapped off. I don't know how I didn't see that coming but I didn't and looking at the other 5, they look like they're ready to snap too. How do I get these bolts off without destroying them?
In England, they drive on the left side of the road. In New England, we drive on what's left of the road.
1997 SL2, 107K miles ~ My first car, trying to make it count
Add to Zeebins's Reputation
Zeebins is online now   Reply With Quote
Old 05-17-2018, 12:41 PM   #2
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
Default Re: How do I get the front bumper cover off
Snap them and replace them with new hardware.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 05-17-2018, 12:43 PM   #3
Zeebins
Zeebins's Avatar
If I do that would i have to retap any of the holes? Thinking about it I realized the bolts are probably just going into the bumper cover itself.
Old 05-17-2018, 01:11 PM   #4
Waiex191
Waiex191's Avatar
They are clip nuts. You can get them at the auto Parts store.
Bryan Cotton
Old 05-17-2018, 01:15 PM   #5
Zeebins
Zeebins's Avatar
So the clip nuts just clip onto the plastic bumper? sounds easy enough. Is there a specific size I need to get? I'm assuming it's the same size as the bolts now, 7mm
Old 05-17-2018, 01:57 PM   #6
cgg17
cgg17 is on a distinguished road
cgg17's Avatar
1994 SL2
Take an old one in and match it up. After removing those bolts remove the push pins on the bottom of the bumper and top by the hood latch then pull forward. Disconnect the side marker lights then it should be clear to pull off completely.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1999 Sl2 4spd: 93,5xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-17-2018, 02:08 PM   #7
Zeebins
Zeebins's Avatar
Doesn't seem too hard, I managed to pull one of the clips off by bending the plastic back a little bit. I'll take it to the store with me tomorrow to match up with some new ones. Thanks for the help guys
Old 05-17-2018, 09:05 PM   #8
Zeebins
Zeebins's Avatar
So I have a similar question now, are the door panels held on with the clips too? A few days ago I was trying get the drivers side panel off to get to the window regulator but 2 of the screws on the bottom where just spinning and one was rounded for some reason. I know the only way I'll ever get them off is to cut the heads off the screws but I didn't do that at the time because I didn't want to have to retap any holes.
Old 05-17-2018, 10:16 PM   #9
cgg17
cgg17's Avatar
1994 SL2
On the bumper you broke the bolts that are in the tabs, as the head is gone. Now for the door, the bolts are still in. So, you snapped the tab on the panel that holds the clip. You will need to either cut the head off or get the panel off enough to get pliers on the tab. On first gens that I have messed with at the JY, I havenít snapped any, but every second gen Iíve touched I have snapped at least one per panel. I think the first gens had thicker panels and more supported tabs. So, if you want to get it off without breaking tabs, I would cut the heads off of the bolts and then get new ones later and use a hefty amount of anti seize compound before reassembly. Itís a PITA but nessecary if you want to retain the unbroken tabs.
Old 05-17-2018, 10:37 PM   #10
Zeebins
Zeebins's Avatar
The thing that snapped the tabs on the panel probably wasn't me but a truck that backed into it about 12 years ago, lol
I'll definitely try this though when I do eventually try to remove the door panel again. What about the tabs that are already broken though, is there anything I can do about those?
Old 05-18-2018, 06:42 AM   #11
Waiex191
Waiex191's Avatar
If the bolts just spin, the tab has broken and you are spinning the clip nut. Most likely​ it won't retain the door skin anymore. If you can remove the rest of the tabs it should come off. My driver's side door skin is missing at least 4 fasteners. OldNuc suggests velcro as one fix. Someday I'll fiberglass up some new tabs.
Bryan Cotton
Old 05-18-2018, 06:48 PM   #12
Saturn Night
Saturn Night is a jewel in the roughSaturn Night is a jewel in the roughSaturn Night is a jewel in the rough
The bolts inside your fender liner have been covered. The next bolts that will likely be problematic, will be the two 10mm nuts that run through the fender to the bumper, by your side marker assemblies.
They have a bad weld, that cracks when you try to break them loose. I had to hacksaw my right side bolts, because they snapped the stud welds to the bracket and you couldn't get channel locks or vice grips to hold the studs.
when I bought my SC2, I had to replace the RT fender, so I also chopped through the fender to get to those studs. They were miserable.
Old 05-18-2018, 07:07 PM   #13
Zeebins
Zeebins's Avatar
10mm nuts? I replaced the bumper eariler and I didn't have to touch any 10mm nuts running through the fender. Just the 6 7mm nuts and some push pins. Are you referring to the bolts that the bumper hooks onto?
For Sale: Front end bumper cover, Hood cover, and Dash cover firevswater5 Classifieds 2 08-04-2006 10:24 PM
Need a red front bumper cover? Turducken Classifieds 1 03-04-2006 05:33 PM
97 SC Front Bumper Cover jericspencer Classifieds 2 12-01-2005 11:10 AM
WTB: front bumper cover for '97 sl2 SimPlyxTriPPiN Classifieds 1 10-09-2004 04:46 AM
needed front bumper cover/ front right fender 99sc2 Classifieds 1 02-03-2004 10:28 PM
