Old 05-17-2018, 10:02 PM   #1
Lightfoot2002
Lightfoot2002 has a spectacular aura aboutLightfoot2002 has a spectacular aura about
Default Leather shift knob.
Hello All. I want to replace the plastic gear shift knob on my 02 SC2 with the leather optional one. I know that the original ones are hard to come by. Are there any after market ones that are identical to the original leather type? And will they fit the gear shift shaft? Thanks to all.
Add to Lightfoot2002's Reputation
Rate the quality of this post and help Lightfoot2002 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lightfoot2002 is offline   Reply With Quote
Old 05-18-2018, 09:58 AM   #2
Default Re: Leather shift knob.
Manual trans?
OEM knob presses over a plastic retainer that circles the shifter shaft, held on by friction. AFAIK, it's unique to Saturn. There is a cutout at the top of the shaft that makes the front of the shaft flat, keeps the knob pointed forward and prevents it from spinning on the shaft (crappy MSpaint drawing attached)
Most aftermarket knobs that I've seen have a retainer ring underneath the knob, with set screws (Allen) that are supposed to hold on to the shaft.
The OEM leather knob is a plastic knob underneath, with a bit of foam (I think) and leather stitched over it - someone here cut open a leather knob and took pics. If you have time and patience, you can make a perfectly fitting DIY leather cover. Just search these terms for videos and How Tos
diy leather cover shift knob water baseball stitch
I did put on an aftermarket leather knob on my SL2 about five years ago, so probably put 50~60k on it without the screws coming loose. Pics in this post
http://www.saturnfans.com/forums/sho...postcount=1943
New leather shift knob... none of the adapters fit the weird Saturn D-shaft. I started with a piece of garden hose for a cheap DIY adapter. Ended up stripping the vinyl outer skin of the hose from the rubber internal, and just a small (maybe 1/3 inch wide) piece of the green vinyl (less than 1/16 inch thick) made the new knob fit on very tight.
Basically, the shaft on the Saturn was a bit narrower than the set-screw collar on the aftermarket knob. A small bit of vinyl garden hose made it a really tight fit and gave a surface that the set screws could bite into.
Old 05-18-2018, 11:53 AM   #3
This indicates DIY is harder than it looks. I still plan on trying, though
http://www.thehogring.com/2017/10/10...ob-in-leather/
A while back, I found a good How To, think it included tips on shrinking the leather to fit the knob well but I could not find it. Some info for myself, for future reference.
something from a Miata forum
I made this one on my second attempt. Not so hard. An upholstery guy told me not to use thick hide - use thin belly leather instead because it stretches and is easier to hand sew. I used an old men's size XL leather glove, which gave me just enough for two - one for practice.
I got the pattern by wrapping some 2" tape around the knob, cutting it so the mating edges were vertical, and then unwrapping. . . .
I was going to try a baseball pattern, but it was too hard to figure out.. . .
Get yourself some leather needles and waxed canvas twine, and just whipstitch it by hand. Join the top to the side first, slip it over the knob, and sew it on in place. Total time spent: 2 hours.
If you preprick all the holes before you stitch it together, you don't need a heavy-duty machine at all. . . .
I would make a paper pattern first. Followed by one or two examples with a medium thick felt. That will show you exactly where your stitching needs to go and the shape of your pieces. Once that far, then you transfer to your leather, prick the stitch holes on a piece of scrap wood and then assemble on the knob while watching tv. . . .
run the leather about 1/4" longer than the bottom of the knob, and then stitch thread around the perimeter of the "tail" to make kind of a drawstring sack. This lets you cinch up the bottom right up to the shifter rod for a nice tight transition to the shift boot. . . run the leather about 1/4" longer than the bottom of the knob, and then stitch thread around the perimeter of the "tail" to make kind of a drawstring sack. This lets you cinch up the bottom right up to the shifter rod for a nice tight transition to the shift boot
http://www.instructables.com/id/Leat...hift-bootknob/
Leather shift knob Q's... Craig S-Series Mods 8 06-01-2008 10:59 PM
OEM Leather Shift knob SLeepr Classifieds 4 03-10-2004 03:58 PM
WTB: Leather Shift Knob LoveMySL1s Classifieds 19 09-25-2003 09:48 PM
Leather shift knob piratepress Classifieds 3 07-15-2002 01:30 PM
Leather Shift Knob David 93 SL2m Mods and Performance 5 01-21-2001 09:18 PM
