Old 05-16-2018, 02:20 PM   #1
tcndeb
tcndeb is on a distinguished road
Default Slave Cylinder Or Master Cylinder?
Anyway to diagnose between the 2 before I start buying parts? Pedal goes to the floor, but I'm not losing any fluid anywhere.
'04 Base Model Vue, 2.2, 5 Speed
Add to tcndeb's Reputation
Rate the quality of this post and help tcndeb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tcndeb is offline   Reply With Quote
Old 05-16-2018, 02:59 PM   #2
waiter21
waiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of light
2003 VUE 2.2L
Default Re: Slave Cylinder Or Master Cylinder?
Unplug the hydraulic hose where it plugs into the transmission slave cylinder.. You remove a clip and the connector will come off.
Gently, attempt to press the clutch pedal. If it wont move, you have a bad slave. if it goes to the floor easily, you have a bad master.
The hose connector that plugs into the slave cylinder has a check valve in it. This prevents fluid from leaking out when its disconnected. This is why the pedal shouldn't move when the hose is disconnected, because the fluid can't go anywhere..
WARNING - DO NOT press hard on the pedal, as you will break the plunger, then you will be replacing the master cylinder assembly
Add to waiter21's Reputation
Old 05-16-2018, 03:17 PM   #3
waiter21
2003 VUE 2.2L
In this photo, you can see the clip that you need to remove to release the hose connector.. This portion of the slave cylinder stick out from the bell housing and your hose plugs into this.
After you remove the hose, re-install the clip. The hose will push back in and the clip will catch it.
Old 05-16-2018, 03:29 PM   #4
tcndeb
Thanks waiter. I'll post a follow up in a couple of days.
Old 05-16-2018, 03:31 PM   #5
waiter21
2003 VUE 2.2L
DO NOT press the pedal hard. You shouldn't put any more pressure on the pedal than is normally required.
I'd recommend cleaning the slave area with brake cleaner or something before disconnecting. That way the area will be clean when you re-install.
When I replaced my clutch and slave, it was because the slave blow out and dumped fluid all over the place..
Good luck.
Old 05-17-2018, 12:41 PM   #6
tcndeb
With the line disconnected, the pedal went to the floor with almost zero effort, and just a tiny dribble of fluid came out of the line. I would say the m/c is bad and will replace. Don't know if the slave is bad or not, but a new m/c will be the first move.
Thanks again for the help waiter.
Clutch Master and Slave Cylinder hddave43 S-Series Tech 8 07-13-2014 10:31 AM
slave cylinder master cylinder dano2201 S-Series Tech 2 04-30-2014 03:52 PM
CLutch master cylinder/slave cylinder azwesjr S-Series Tech 1 12-26-2013 09:26 AM
CLutch master cylinder/slave cylinder removal Tjflow S-Series General 7 02-17-2010 04:43 PM
5spd master/slave cylinder jasonsl2 S-Series Tech 1 02-14-2005 03:50 PM
