Old 05-16-2018, 06:52 PM   #1
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Spark plug wires routing....
Replaced the spark plug wires this evening,
Managed to keep straight the wires in the two clips nearest the plugs...
But the ones in the grey one nearest the coil packs got loose...
(Has a slot in it, slides on a clip)
What order do I put them in?
Wires I took out said “Packard”, so they were OEM...
Many Thanks...
And I spotted BP Autran TES 295/468 fluid for 25 a gallon at NAPA...
Plain Dexron III was $3.50 a quart...
2002 Silver SL2, manual, 5th gear swap (.605), 79,900 miles, black badges,
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 05-16-2018, 07:02 PM   #2
Default Re: Spark plug wires routing....
Ignition wire routing as seen when looking at the engine and coils from the front, hood open, your left to right.
Engine
1-2-3-4
4-1-2-3
coil towers
Connect the matching numbers with a plug wire.
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 07:29 AM
Dealer pricing on spark plug wires and spark plugs. KeithR S-Series General 25 05-19-2011 11:52 PM
SOHC spark plug wire routing NYB77 S-Series Tech 19 05-18-2011 06:10 PM
spark plug wires bdobraj S-Series General 12 05-03-2010 01:32 AM
spark Plug wires Natha137@aol.co S-Series General 11 09-10-2004 11:42 PM
