Old 08-02-2019, 02:50 PM   #1
Ryantdixon1996
Ryantdixon1996 is on a distinguished road
2007 ION-3 Sedan
Default Ion3 2.2 Vin F 2007 No power
Just got finished rebuilding and installing the head & reconnected the battery to do the first start, saw a small spark and when the remote locks didnt work I assumed I blew a fuse. Then upon further inspection and no blown fuses, there is power at the fuse block and fuses but only dim illumination lights in the car no radio/etc and the illumination is only dim with headlight switch on. Mind you headlights dont turn on either.
EDIT-
Done so far:
Double checked battery connections
Double checked underhood fuses
Double checked engine grounds
Tried a jump
Swapped arround some of the 30amp fuses labeled battery.
To do:
Test all fuses for continuity
Triple check all connections on engine/grounds
Any ideas? Not sure what im missing ive searched the forums and web pretty thoroughly . Thanks!
Add to Ryantdixon1996's Reputation
Rate the quality of this post and help Ryantdixon1996 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ryantdixon1996 is offline   Reply With Quote
Old 08-02-2019, 06:49 PM   #2
Default Re: Ion3 2.2 Vin F 2007 No power
Welcome to SaturnFans, Ryantdixon1996!
What was the voltage reading at the fuse block? Has battery voltage been verified? It is possible to have adequate voltage there while having inadequate cranking capacity to turn the starter. IMHO, if the battery checks out okay then you may need to look for a bad ground wire or perhaps a poor ground connection.
313,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 08-02-2019, 08:05 PM   #3
1- Some vehicles have two or three fuse panels. The engine fuse panel has main fuses while the second or third fuse panels are inside the vehicle by the console or foot well.
2- With electronics in many vehicles, disconnecting and reconnecting batteries usually results in some sparks from the surge of power needed for sleeping electronics to wake-up. Normal under most circumstances and usually nothing to worry about except in some instances. If all the fuse panels don't have a blown fuse, try disconnecting battery negative
for 10 seconds then reconnect. All electronics are designed to sleep when power is completely removed like periodic maintenance to disconnect battery power when working on electrical or electronics, battery replacement, dead battery from killing it in freezing winter startups or attempting to weld when inadvertently shorting live wires. When power is restored, electronics sometimes wakes up in a confused state (alarm turns on, horns honk, etc). If this occur either use the remote to turn off factory alarms or disconnect the battery for 10 seconds. Reconnecting should reset all electronics again.
3- If a battery boost didn't help, maybe electronics is confused and needs a complete battery disconnect as suggested in step-2. Worse case scenario is the battery may have a partial charge requiring a full charge before trying everything again.
2007 ion3 dash lights jss2 Ion Tech 1 09-30-2011 07:05 PM
Front end rattle...2007...ion3 reevesjo Ion General 8 04-19-2011 09:54 AM
2007 ion3 fog lights jss2 Ion Tech 6 06-26-2010 01:37 AM
2007 ion3 dome/map lighs jss2 Ion Tech 3 03-16-2007 04:45 PM
considering Ion3 Quad Cpe 2007 gilloz Ion Tech 13 09-03-2006 12:39 PM
