Old 12-14-2013, 11:05 AM   #1
jmelvin8
jmelvin8 has a spectacular aura aboutjmelvin8 has a spectacular aura about
jmelvin8's Avatar
2001 L-Series 3.0L Sedan
Dazed Speedometer/odometer not working, OBD showing all codes
I recently had went out of town. Upon arrival to my 2001 Saturn L300 3.0L everything seemed to be fine, until two days later. The battery had for some reason decided to quit after I drove her a couple days after my arrival. So, I had changed the battery and when I did my speedometer/odometer were not working anymore. So I checked to see if it was a fuse, no luck.
Then I thought maybe I should check the OBD, just in case it was something more major. Well I guess it is major, because it had shown all codes. Is this a BCM issue or is my computer toast? Thanks in advance!! Also my emissions is coming up and this isn't always the best position to be in before such a situation.
PS: I also had seen that there was a specialty recall for the BCM in my VIN range, but I am not included in that recall. I checked with two GM dealers with my VIN and they said it wasn't included in the BCM specialty recall.
Add to jmelvin8's Reputation
Rate the quality of this post and help jmelvin8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jmelvin8 is offline   Reply With Quote
Old 12-14-2013, 11:53 AM   #2
Default Re: Speedometer/odometer not working, OBD showing all codes
Is the MIL/CEL indicator ON? This is the engine symbol in yellow. If on when the engine's running then error codes are stored for immediate retrieval. Battery replacement and the check engine light are coincidental and not a battery caused problem. There are two ways to address this - either panic or try some simple checks to find out why a sudden list of error codes pop up. The easiest check is to remove and inspect fuses in three places, in the engine area and right/left foot wells after removing plastic access panels. Each panel has a fuse puller tool. Removing fuses are the only way to see blown elements. Fuse inspection will eliminate power failure in electronics that can generate false error codes.
Search threads within the L-series to become familiar with bcm failures and symptoms. Error codes with a 'P' prefix are usually emissions control related - failing state emission inspection automatically if not corrected. Retrieve all error codes for listing here and Googling if you need to find their definitions. Refrain from manually resetting error codes; near inspection, a manual reset forces the emissions parameters to default factory conditions requiring at least a 50 mile 'drive cycle' to allow all on board emissions testing to fulfill restoring parameters before 'readiness monitors' go to 'pass', allowing state inspection to pass. The check engine light may be off but emissions self tests are performed every time the engine is started, car driven. Continually resetting the check engine light simply forces the emissions tests to start from the beginning, prolonging completion. All repairs and corrections are detected automatically by the on board diagnostics that know which repairs corrects an issue to erase each error code and put them into a 'pending' file that requires the drive cycle to complete testing. Some tests need three engine cycles free of the same error before the light turns off to ensure no one is manually resetting computers. Others need only one engine start to erase an error code.
If you determine your bcm failed then there are two choices; used bcm's or new replacements from GM (only). Used bcm's retain mileage from where it came from and losing remote use. Remotes are programmed by GM (only) but mileage cannot be altered. New bcm's are programmed by GM.
Old 12-14-2013, 02:43 PM   #3
jmelvin8
jmelvin8's Avatar
I don't have the engine symbol in my instrument cluster, but my " Service Engine Soon" light is on though. I did check all my fuses, hood/left and right foot panel, and everything is fine there. When I had taken it to my local auto parts store and had them check the codes, the individual told me I was going to have to take it to a shop to get some answers since it was showing ALL codes present with the vehicle. I can't find the print out, but it was all of them and clearly a handful of those were not the issue when I had looked at them myself. I had him try and reset from his obd reader and I have tried a few attempts with disconnecting the battery and draining a charge from the system. It still showed ALL codes upon return to a different parts store. I do know that my Saturn had it's BCM was replaced in early 2007, which makes me wonder if my BCM is ok. I'm unsure. What strikes me as strange is once the battery swap occured, no Speedometer, odometer stopped at 85000 and the OBD throwing every single code at me. What could cause the OBD to throw all it's codes? Thanks!
Old 12-14-2013, 03:24 PM   #4
If you had one bcm replacement and suspect this one is failing (you haven't confirmed this against posts with definite bcm failure) then you may be the first here to have a repeat problem. I don't know if this is a bcm failure or not as you're only pointing to two failures that are bcm related (speedo and odo display are from the bcm). The ecm still calculates tach and speed info that it passes to the bcm for display. On one hand, you're fortunate as bcm failure can cause a complete failure to start and run the engine; the bcm has GM's Passlock theft deterrent program and it has failed by activating Passlock, disabling injectors permanently to prevent engine running. Early bcm failures resulted in a tow to Saturn to replace failed bcm's.
With state inspection coming soon, you may have to bite the bullet and have GM diagnose the problems.
Old 12-14-2013, 03:33 PM   #5
jmelvin8
jmelvin8's Avatar
Is it possible the ECM could be bad, if ruling out the BCM? Could ECM failure cause the OBD to puke out all it's codes? Ha. I am going to rule out the BCM at the moment, so that I can approach it with a different frame of mind.
Old 12-14-2013, 03:46 PM   #6
The engine control module (engine computer) runs the engine. The body control module runs everything else except the airbags, xmission, and ABS/TC system. Those are operated by their own modules. All communicate to the bcm for the on board diagnostics as its the gateway for plugging in readers/scanners/whatever thru the DLC port under the steering wheel.
If your engine starts and runs the ecm isn't broken.
Is there a possibility for corrosion to set up and cause intermittent connections? While all wiring connections are made to eliminate corrosion, real world conditions dictates otherwise.
Speedometer/Odometer stopped working. turbodub95 L-Series Tech 11 12-28-2009 02:48 PM
93 SL1 Speedometer/odometer not working teamsl1 S-Series Tech 5 12-06-2007 09:56 PM
Speedometer/Odometer Not Working Tom64 S-Series Tech 12 11-27-2007 06:30 PM
Speedometer and odometer not working?! CBXweb S-Series Tech 1 11-11-2006 11:50 PM
speedometer working, odometer not? bryan_johnson S-Series Tech 3 05-15-2003 08:57 AM
