Old 05-26-2006, 01:20 AM   #21
wolfman
wolfman's Avatar
Default Re: saturn transmission problem
A check of my user gallery (just click the little camera next to my avatar) will reveal a diagram of which bolts to remove (and which ones absolutely NOT TO!) to seperate the valve body from the top of the transaxle. A SEARCH of the board should reveal DIRECTIONS posted for another board member by myself as needed. (For free...LOL)
Found the thread! Just click >HERE<
and scroll down...
Add to wolfman's Reputation
Old 11-02-2009, 02:29 PM   #22
4200db
4200db is on a distinguished road
DUDE BEFORE YOU DO ANYTHING CHECK YOUR FUSES UNDER THE HOOD FOR THE LINE PRESSURE SELENOID IT MIGHT NOT BE CRACKED MAKE SURE THE NUMBERS MATCH UP IF YOU HAVE THEM MIXED UP IT WILL SCREW UP THE WAY IT SOULD SHIFT AND IT WILL SLAM INTO GEARS TRUST ME IT FIXED MY PROBLEM AND I TOOK IT TO A SHOP AND THEY PULLED MY TRANNY OUT AND COULD NOT FIND THE PROBLEM SO I EVEN BOUGHT A NEW PCM OUCH IF I ONLY CHECKED THE FUSES GOOD LUCK
Add to 4200db's Reputation
Rate the quality of this post and help 4200db reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
4200db is offline   Reply With Quote
Old 08-21-2010, 01:38 PM   #23
hmm
hmm is on a distinguished road
I have a Saturn SC2. I have had some problems with mine as well. Its an automatic. when it goes to shift into second gear it shifts hard and sounds like the its going to come out the top of the hod. it also feels like its trying to hold you back when it does shift to second gear. I have changed the valve body in it twice and i have been told it might be my transmission. I have done some much work to it and still its doing it, what do you think it could be before i buy a transmission?
Add to hmm's Reputation
Rate the quality of this post and help hmm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hmm is offline   Reply With Quote
Old 08-21-2010, 02:24 PM   #24
Chazberry
Chazberry's Avatar
1995 SW2
Welcome to Saturnfans!
Are you getting an SES light? If so, it would help to get the codes read. Common DTC is P0732 - Gear 2 Incorrect Ratio. Since you have already done the VB, this would point to the famous Input Shaft Nut . . .
http://www.saturnfans.com/forums/showthread.php?t=98659
Add to Chazberry's Reputation
Old 08-21-2010, 08:10 PM   #25
hmm
ok thanks, but what is the Input Shaft Nut? and where can I find it?
Old 08-21-2010, 08:32 PM   #26
Chazberry
Chazberry's Avatar
1995 SW2
It's behind the End Cover on the Tranny. You'd be starting at Step 10 in this thread . . .
It's the 23mm nut indicated in this pic . . .
http://www.saturnfans.com/forums/att...0&d=1281563554
Old 08-21-2010, 10:25 PM   #27
hmm
If i have to get the piece, where would i be able to get it and how much? thanks so much for your help i'll have someone check it out.
Old 08-21-2010, 11:13 PM   #28
Chazberry
Chazberry's Avatar
1995 SW2
These are the parts, less than $20, at any GM dealer:
Output Nut - SN21001679
Input Nut - SN21001680
Gasket - SN21001684
You need a thin-wall 23mm socket to get at the Input Shaft Nut.
To quote the FSM: "NOTICE: Use a new nut due to insufficient torque retention of old nut. Clean shaft threads with wire brush. When tightening and torquing this nut it must be done quickly. The thread locking material used on the new nut will cure in a short time resulting in incorrect torque."
Both Nuts need to torqued to 111 ft-lbs.
Old 08-21-2010, 11:50 PM   #29
Chazberry
Chazberry's Avatar
1995 SW2
PS - I should have asked: Are you having any problems with Reverse?
Old 08-22-2010, 03:20 PM   #30
hmm
Well the last time before we changed the valve body we did have trouble with all gears they shifted hard, and this time after changing the valve body we are having trouble with it going into second it feels like its trying to hold you back,but when it does goes into second gear it shifts hard (sounds like its going to pop out of the hod.) i hope this makes sense. thanks
Old 08-22-2010, 08:41 PM   #31
Chazberry
Chazberry's Avatar
1995 SW2
Well - a loose Nut usually affects Reverse and 2nd, so if you don't have any Delayed or Slamming into Reverse, you might have some other problem. How about an SES light - have you tried to get some codes read?
Old 08-22-2010, 08:58 PM   #32
hmm
Well it has problem wanting to go to second then when it does go to second(automatic)it then like shifts hard/slams or jerkys i guess you can say. As far as the SES light I dont have that to come on. No lights come on except Coolant light then sometimes it goes away. some say that the transmission is sending metal shavings to the valve body, but i dont know have had the Valve body changed in it twice.But also was told it was the Torque Converter. thanks for advice hope you can help me figure it out. thanks again
Old 08-22-2010, 09:32 PM   #33
Chazberry
Chazberry's Avatar
1995 SW2
Has the tranny fluid and filter been changed lately?
Old 08-22-2010, 10:30 PM   #34
hmm
Actually to be honest with you, the guy that worked on it the last time when he changed the valve body never changed the trans fluid or filter he said that it was fine and that it was clean, but i thought it would have to be changed any ways. so no it wasnt changed. i hope we can figure it out.
Old 08-22-2010, 10:37 PM   #35
Chazberry
Chazberry's Avatar
1995 SW2
If you don't know when it was changed last, even if it looks clean on the dip stick, it might be worth draining the fluid to see if much metal comes out. I think it's very strange that you're not getting an SES light, considering the harsh shift into 2nd. I also don't think a Torque Converter problem would cause a problem with just one gear. And TC failures are not very common with these cars.
Old 08-22-2010, 10:55 PM   #36
Originally Posted by Chazberry View Post
If you don't know when it was changed last, even if it looks clean on the dip stick, it MUST be changed NOW.
It doesn't matter what color it is, how much metal is in it, whether it goes well with fava beans, if it has more than 30,000 miles on it, it's overdue.
Add to madpogue's Reputation
Old 08-22-2010, 11:08 PM   #37
hmm
Thanks for the advice, i dont know the last time it was changed there is 92,000 miles and we changed 2 valve bodies with 6 months. the first time we took it to a shop so they may have changed it, i have no clue. but thanks i can try that first and pray that it works.
Old 08-22-2010, 11:31 PM   #38
Chazberry
Chazberry's Avatar
1995 SW2
And it might be worth hooking up a code reader even if you don't have an SES light now - maybe there's some stored codes that might provide a clue.
Btw - did you ever say what year SC2 this is?
Old 08-22-2010, 11:35 PM   #39
hmm
not sure but its a 2001 and its 1.9 with the D.O.H.C
Old 08-22-2010, 11:39 PM   #40
Chazberry
Chazberry's Avatar
1995 SW2
OK - that means it's OBDII and you might be able to retrieve some stored trouble codes.
2000 saturn ls1 transmission problem strumfetica L-Series Tech 4 10-15-2009 11:44 AM
1998 Saturn SL2 Transmission problem jpoell01 S-Series Tech 7 09-04-2009 01:56 PM
2000 Saturn SL2 - Second Transmission Problem usairwaysjett2 S-Series Tech 6 06-13-2009 09:52 AM
2000 Saturn SL1 Transmission Problem Mike D S-Series Tech 4 11-05-2008 12:39 PM
1991 Saturn SC auto transmission problem slydog S-Series Tech 7 07-21-2008 10:29 AM
