Old 02-16-2009, 10:33 PM   #1
jpoell01
jpoell01 is on a distinguished road
Default 1998 Saturn SL2 Transmission problem
I have a 1998 1.9 L DOHC SL2 Saturn and just put a used transmission in to replace a faulty one (the transmission was believed to be working fine). With the transmission in in drive, it will not shift out of first gear - however, in 2 and 3 it will operate and shifts normally. Both the old and new transmissions were MP7's. Any help is greatly appreciated.
Add to jpoell01's Reputation
Rate the quality of this post and help jpoell01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpoell01 is offline   Reply With Quote
Old 02-17-2009, 12:30 AM   #2
rc1488
rc1488's Avatar
Default Re: 1998 Saturn SL2 Transmission problem
What year is the new tranny?
'98 (maybe '97) - '02 are the only compatable years.
Make sure you put all the wires back on the tranny and all grounds are on the top tranny bolts
Add to rc1488's Reputation
Old 02-17-2009, 10:41 AM   #3
jpoell01
The tranny came out of a 1998 SL2 - so they should be identical.
Old 02-17-2009, 11:33 AM   #4
Is your SES light on? Does the SES light work?
Add to madpogue's Reputation
Old 02-17-2009, 08:20 PM   #5
jpoell01
No, the SES light is off and it does work. I am not getting any unusual reading from the gauges either.
Old 02-17-2009, 08:38 PM   #6
It takes very little additional series resistance to effectively fail the low fuel light.
Old 02-18-2009, 09:59 AM   #7
Thecommi
Thecommi is on a distinguished road
I've had this problem before, I pulled a good working transmission out, and it sat for about 6 months before i found a car to put it in. I came to the conclusion that it was due to a bad pressure solenoid in the valve body of the transmission from sitting to long. I replaced the valve body, ebay.... and the problem was solved.
Add to Thecommi's Reputation
Rate the quality of this post and help Thecommi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thecommi is offline   Reply With Quote
Old 09-04-2009, 01:56 PM   #8
kwhtn
kwhtn is on a distinguished road
Dizzy Re: 1998 Saturn SL2 Transmission problem
Unfortunately, with trans problems, there can be many reasons for a set of errors, and the SES diags may not call them all out. Here's a few for kicks:
1. Aside from the obvious, trans fluid where it's supposed to be, good connections, good ground, good valve body, good internals;
2. The gear selector switch has to be adjusted to just the right spot. (Check for continuity on the test lugs on top of switch with gear selector in Drive). The Haynes manual said it needed to be adjusted in Neutral--WRONG!
3. The transmission, engine, PCM, Under the hood junction box (UHJB), and wiring harness must all match up! This is critical because the gear ratios in the MP6, and MP7 were different. This means the VSS is sending different info to PCM, and engine info will be different, hence confused shifting. Even though the UHJB (fuse box) looks the same as the car you got the transmission from, it may not be the same. Check the serial number on your PCM to make sure they are the same.
4. If you have taken the connectors loose from the PCM at all, you could have spread the little female pin connectors so that they no longer make good connection. I had to painstakingly take each one out and adjust them to be tight again to make a car work right once. (Did I mention that was a pain?)
5. If you have taken the valve body apart, you could have spread the contacts on the solenoids so that they don't make proper connection anymore. Saturn recommends changing the solenoid bus anytime you take it out.
6. The wiring in the UHJB must match with that required for your gear selector switch, and fuse block, and 10 pin connector on top of your trans.
7. After all that, you must have good sensors on your transmission (all correct and functioning).
Oh, and by the way, you can't create problems in wiring and connections as you go along, or you'll not think to go back to those areas until after you've brought out the tools of last resort (sledge hammer, shotgun, spare derby car, gun-powder, etc).
Add to kwhtn's Reputation
Rate the quality of this post and help kwhtn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kwhtn is offline   Reply With Quote
2000 Saturn SL2 - Second Transmission Problem usairwaysjett2 S-Series Tech 6 06-13-2009 09:52 AM
Will a 1997 saturn sc1 manual transmission work in my 1998 manual sl2? CARLiTO_ S-Series Tech 1 08-19-2008 08:52 PM
1998 SL1 Auto Transmission Problem Spreck13 S-Series Tech 2 03-31-2008 01:34 PM
1998 Saturn SL2 Manual Transmission Cable broke for my wife S-Series Tech 5 02-02-2008 12:04 PM
Reverse Problem, 1998 Saturn SL2 SlyTCat S-Series General 2 08-05-2006 11:32 AM
