Old 04-20-2008, 04:59 PM   #1
Keej
Keej is on a distinguished road
1999 SL1
Default Power steering rack
Does anyone know if you can swap a variable (SL2) rack with a non-variable (SL1) rack? 96 has the variable, non-variable is 2002.
Thanks fellow gear heads
Add to Keej's Reputation
Rate the quality of this post and help Keej reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Keej is offline   Reply With Quote
Old 04-23-2008, 01:06 AM   #2
virnin
virnin is on a distinguished road
virnin's Avatar
Default Re: Power steering rack
The two racks should bolt up the same and may very well be identical. The "variable" control is on the power steering pump in the form of an electrically variable orifice, EVO. The signal to the EVO is proportional to the vehicle speed but I've no idea where you would find that signal on an '02. The '96 only has one computer but the '02 has two, the PCM and the BCM. You would have to find the wiring diagrams for an '02 to determine where to wire in the EVO connector on the power steering pump.
Add to virnin's Reputation
Rate the quality of this post and help virnin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
virnin is offline   Reply With Quote
Old 04-23-2008, 05:08 PM   #3
Keej
1999 SL1
Thanks for the reply virnin. The racks appear identical, and the swap is the 02 SL1 rack into the 96 SL2. The original EVO pump in the 96 would be connected to the 02 SL1 rack. Just wanted to see if anyone knew of a problem that would show up with this swap.
Thanks
Power Steering Rack tgaff L-Series Tech 15 02-20-2007 10:54 PM
power steering leak/steering rack question Gadweller S-Series Tech 9 11-19-2005 03:18 PM
WTB: Power Steering Rack amazinghl Classifieds 3 08-23-2005 11:39 PM
power steering rack lines geartooth94 S-Series Tech 13 05-18-2005 11:05 AM
Power steering rack SC2 mkdavies S-Series General 2 02-24-2005 12:38 PM
