Old 01-01-2006, 04:23 PM   #1
MacExperts
MacExperts is on a distinguished road
MacExperts's Avatar
1999 SW2
1992 SL2
Default rear wheel cylinder rebuild information in case any1 wants it
i rebuilt both rear brake wheel cylinders in the 92 sl1
i had posted a Question on these previously so i am including my experience for the forum should anyone need it in the future
it was a lengthy and methodical job but not difficult, work on one side at a time as usual or get a cheap manual with pictures (i used the haynes) so you can put everything back together
the rubber piston seals and dust caps/end caps are difficult to replace on the two pistons in each cylinder
but with patience you can stretch them onto the pistons by hand provided you have strong fingers/hands (i have large strong hands but even i had to pause several times since the force needed is so much your hands fatigue)
i recommend that you hone the cylinders if you have a hone/drill
if not, depending on condition of the cylinder bore, you may be able to just
use sheet sandpaper and a small screwdriver to clean the interior/wall (wrap sandpaper around screwd or small cylinder that fits and push in and out and rotate)
clean with break cleaner spray and sandpaper a few times til the insides are like new, a good seal is a must -- when i put the pistons back in they were very tight (good sign, if they are not then the cylinder metal might have rusted down or worn down and you basically cannot rebuild them so just buy new in that case)
i had bought the rebuild kits a # of years back when the wheel cylinders were running around $35~40, they are much cheaper now, like under $20 maybe $15 if memory serves so the savings isn't as substantial as it once was
i believe the kits alone were around $10 back when the wheel cylinders were in the $35-40 range so it was worth it
now i do not see the rebuilt kits listed at at least one supplier anymore (only checked 1 so if you need/want them shoparound they may still be avail.)
haynes says not recommended to rebuild but i don't see why
there was nothing unusual as far as wheel cylinders go and i've rebuilt my share over the years, the saturn wheel cylinders are very solid/well built
but if the new cylinders are 1/2 the price of a few yrs back then
your savings isn't much for the extra work involved
in my case i already had the kits and my small leak had grown enough to get me working, i replaced shoes while back there also naturally
MacExperts is offline   Reply With Quote
Old 01-01-2006, 04:42 PM   #2
JS593
JS593 is on a distinguished road
JS593's Avatar
1992 SL1
Default Re: rear wheel cylinder rebuild information in case any1 wants it
Wheel cylinders for rear drums costed me 10$ CAD. shouldnt be much mor then 15 US.
92 SL1 SOHC TBI
Custom intake
Alpine deck, speakers, amp
JBL Sub
Ultimate amp
Volometer gauge mounted in dash
Magnaflow exhaust
....DEAD.... Car towed away Jan 18 2007. RIP
JS593 is offline   Reply With Quote
Old 01-01-2006, 06:47 PM   #3
peppermrj
peppermrj is on a distinguished road
peppermrj's Avatar
Post Re: rear wheel cylinder rebuild information in case any1 wants it
I just recently purchased two rebuild kits for the 96. They were $7.50 each. Wheel cylinders were $15.00 each.
Not a big difference but on other vehicles (read rear wheel drive) replacing the wheel cylinder required taking off the metal brake line. 9 times out of 10 they were rusted together. Now you are replacing brake tubing. That can be a real PITA.
Saturn rear wheel cylinders are attached a lot like front calipers. They have a flex line, block, and banjo bolt setup. Much simpler removal.
I would say to try opening the bleeders on the wheel cylinders first. If they give you any problem don't bother and repace the whole wheel cylinder. If they come loose hit them with a little never seize before reassembly and go for it.
peppermrj is offline   Reply With Quote
Rear Wheel Cylinder-mounting bolt K2112S L-Series Tech 13 02-23-2020 01:58 PM
Master Cylinder rebuild kit???? Sturnssuje S-Series Tech 11 07-14-2009 10:29 PM
Saturn Rear Drum Wheel Cylinder Inspections Bullet Vue Tech 0 11-13-2005 04:10 PM
SL1 Wheel Cylinder Rear (Rebuild??) MacExperts S-Series General 0 03-12-2005 02:00 AM
rear wheel cylinder goldenSL1 Miscellaneous Tech 3 08-19-2002 11:32 AM
