Old 07-07-2005, 04:38 PM   #1
71_307
71_307 is on a distinguished road
Default yes a motor mount question
hi.. havent posted in a real long time here..but im back... my lower motor mount im guess its the passanger side one has gone.. just woundering cause i cant find anything on it in my chilton.. do you have to torque the bolts for it??? and any tips for removing it that will make it eazyer to remove.. sorry for asking i just cant find the remove/install in my chilton.. unless someone knows the page number cuz im blind as a bat and cat find it..
thanks
Dan
71_307 is offline   Reply With Quote
Old 07-07-2005, 06:47 PM   #2
rkuris
rkuris is on a distinguished road
rkuris's Avatar
Default Re: yes a motor mount question
I don't have my Chilton's handy at the moment either, but I do know it's in there. Check in the engine removal section. You obviously have to remove the lower engine mount in order to remove the engine, so the torque specs are probably at the front of that section (2B).
It is not nearly as hard as the transmission lower mount. I think, though, if you are replacing the lower engine mount, you might also want to look at the upper and lower transmission mounts. They might be bad too.
rkuris is offline   Reply With Quote
Old 07-07-2005, 07:34 PM   #3
71_307
thanks for the help... ive replaced the top one and the other one donest look all that bad.. i think the passanger one has had a short life do to a oil leak which has kept the mount cover in oil befor i bought the car, soi think the oil destroyed the mount.
Dan
Old 07-07-2005, 07:41 PM   #4
rkuris
rkuris's Avatar
Could also be from sloppy oil changes instead of an oil leak. The oil filter isn't too far from the mount either.
Old 07-07-2005, 07:44 PM   #5
71_307
that is also most likly true.. does the engine need to be proped up like when removing the top engine mount?
Motor mount question reelon S-Series Tech 13 12-10-2006 01:42 PM
Motor mount question rreuben S-Series Tech 5 11-19-2006 04:16 PM
Upper Motor mount question OU812 S-Series General 5 04-07-2006 09:44 AM
Motor Mount Question SweetSL2 S-Series Tech 4 01-10-2005 10:08 PM
Motor Mount Question Aldiaz2331 S-Series Tech 2 12-13-2003 12:36 PM
