Old 05-27-2014, 06:46 PM   #1
AaronW
AaronW has a spectacular aura aboutAaronW has a spectacular aura about
Default 2002 Saturn. Replaced both headlights, now the drivers side Brights Wont work.
Hit a dog and busted out the drivers side headlight. Changed both sides b/c the passenger side had moisture on the inside. Changed them out and now the drivers side Brights Wont Work and the Dim lights are pretty dim compared to the passenger side. Any advice?
Should say I switched sides on the bulbs and the same thing, normal on the passenger side, dim on the bright side.
Forgot to add that the drivers side was partially busted and I drove it for a little while. Car got washed and the the bulb blew out. Im guessing the water shorted something out?
AaronW is offline   Reply With Quote
Old 05-27-2014, 07:03 PM   #2
AaronW
Default Re: 2002 Saturn. Replaced both headlights, now the drivers side Brights Wont work.
Ok. Got lucky and found the problem. Had a blown 10 amp Fuse.
Issue With Brights... Already Replaced Headlight Switch! tmiller87 L-Series Tech 8 09-23-2020 01:30 PM
Anyone replaced their drivers side transmission mount? Mr_Vexed Vue General 0 09-16-2013 09:57 AM
Drivers Side wiper not work very well? COME ON IN! TIMSPEED S-Series General 1 11-29-2005 11:16 PM
My drivers side window wont roll up bgkycountryboy S-Series General 3 11-01-2005 04:26 PM
drivers side power window wont work sometimes Mike99SC2 S-Series Tech 1 06-25-2001 01:35 PM
