#1 |
![]() Join Date: Apr 2004
1997, SL2, it is my son's car now. Yesterday I noticed that the headlight bank and driving light on the passenger's side of the vehicle is very dim. The driver's side works just fine. I was thinking it was a ground issue, but so far I have not found anything wrong. It doesn't matter if you have the dims on or the brights, but ALL bulbs on the passenger's side glow very dimly at the same time. Could a bad headlight switch cause this? It appears that the passenger side picks up its ground under the hood, just behind the headlight assembly. I see four (4) black wires running to a block that is bolted down. I tried running a ground jumper wire from the battery over to this block, but no change. I don't think it is a hot side issue, as I would think that it would be limited to just a single bulb, not the whole bank. I spent a couple hours on this last night and I all I have is frustration so far.
Any ideas to help narrow the problem down? Thanks for the help, Mike |
#2 |
Well, for some stupid reason, the headlights are ground switched not hot switched. To me that makes it 1000x harder to troubleshoot
![]() Orange : +12v Tan : Low beam ground Green: High beam ground Might have tan & green mixed up, but the headlight switch provides a ground connection through those lines. Blue & brown are parking light & turn signal I believe. Hope this helps.
The proper way to fix a S-Series automatic is to replace it with a 5spd O:) |
#3 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005
Check the right headlamp fuse in the underhood fuse block,check the wires behind the headlamp for any chafed areas. Sometimes they rub on the brackets and eventually blows the fuse.
#4 |
Ok, I think I have this figured out. I guess I will find out tonight when I get a chance to work on it. I have found information that indicates each headlight assembly has it's own fuse and even if you blow a fuse, the lights may still glow dimly. Well, the passengers side driving light went out the other day. In fixing it last night, one of the wires was broken at the connection. I fixed it and installed a new bulb, but I bet when that wire broke, it touched the other terminal and popped the fuse.
I will check tonight and report back. Thanks for the suggestions. |
#5 |
The right lamp ground pack that is right in front of the washer jug and looks like a thin black rectangle bolted to the frame with many black wires entering it. Unbolting is not usually possible but the black connector should disconnect from the multi prong connector and can then be disassembled and cleaned. That will usually fix the driving lights and the marker lights.
#6 |
I was able to unbolt this black ground connection block last night. Everything looked good on the connection to the frame, but I did not disassemble the block. That is another area that I will take a look at, if the fuse proves to be a dead end.
Thanks, Mike |
#7 |
There are several grounds in the light system and that tone is only related to the fogs and right turn/marker lights.
To actually determine where the problem may be you will have to explain which lights are dim and the associated switch positions. Such as DRL, high beam blink, high and lo beam on. There are several ground points. |
#8 |
It doesn't matter which light position I have the car on, the low beam, high beam and driving light are all on, but very dim. Changing from brights to dimmers does not change this.
Mike |
#9 |
Turn off the fog lights.
Turn of the fog lights and then check the headlights. Disconnect the left hand headlight bulbs connectors and see what happens on the right side. Last edited by OldNuc; 02-02-2011 at 03:51 PM. |
#10 |
There are schematics for the headlight system in my gallery and verifying the proper voltage at the bulbs is a good idea. A failed bulb on one side can cause problem on the other.
#11 |
Well, it was the right side headlight switch that was blown. Can someone explain to me how you can still get power to the headlight bank to make the lights dim, even when a fuse is blown?
Thanks, Mike |
#12 |
You end up with the filaments on the side with the blown fuse in series.
#13 |
Sorry, I meant to say it was the right side headlight fuse that was blown, not the switch..
![]() Mike |
#14 |
That is what I figured out.
#15 |
![]() Join Date: Apr 2013
I have a similar problem with the headlights being dim on the left side of the car but when I was trouble shooting I pulled the Left side fuse and nothing happened the light still was on but when i pull the right side both lights go out. It's almost as if both lights are wired into the same fuse. Anyone know what is going on? Worked fine for a year then all of a sudden dim ? no one touched the grounds or anything and the light bulb has been changed as well as fuse.
#16 |
Actually check the left side fuse.
Bookmarks |
passenger side sits higher than driver side | nitsua y zarc | S-Series Tech | 6 | 10-09-2009 11:26 PM |
No high beam headlights right side 97 sl2 | WJ33 | S-Series Tech | 3 | 12-24-2008 05:51 PM |
Saturn/Toyota/Honda Side by Side Test | rayw1199 | General Saturn Discussion | 20 | 06-14-2007 12:55 PM |
Side-by-Side-by-Side Test Drive Program Starts Today | Charlie | Aura General | 0 | 06-11-2007 01:07 AM |
2003-2004 Ion interior side by side comparison pics | KrgION03 | Ion General | 9 | 08-06-2003 10:53 AM |
