Old 12-21-2008, 05:31 PM   #1
WJ33
WJ33 is on a distinguished road
Default No high beam headlights right side 97 sl2
Cleaned all grounds. new high beam headlamp. Any ideas?
WJ33 is offline   Reply With Quote
Old 12-21-2008, 05:37 PM   #2
pimpin88
pimpin88 is on a distinguished road
1996 SL
Default Re: No high beam headlights right side 97 sl2
Check your relay?
Did you disable DRL's? I did this on mine and the jumper wire I used came loose and caused the right side high beam to not function.
pimpin88 is offline   Reply With Quote
Old 12-21-2008, 06:29 PM   #3
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy Re: No high beam headlights right side 97 sl2
Originally Posted by pimpin88 View Post
Check your relay?
I seconded this. If you disable the DRL'S only one high beam will work.
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Old 12-24-2008, 05:51 PM   #4
WJ33
Thanks. The Logic Board In the Cluser Went out. What a job!
HELP drivers side high beam 0 voltage YourMainParadox Vue Tech 4 05-09-2009 03:15 PM
1996 SL2 Drivers side high beam branlee33 S-Series Tech 4 02-06-2008 10:11 AM
Low Beam, but no high beam deligh387 L-Series General 6 12-08-2007 06:30 PM
Fog lights & high-beam headlights Doc_Floyd Vue General 9 04-15-2006 10:55 PM
Projector Beam Headlights? beensmoked L-Series General 2 12-04-2004 06:46 PM
