Old 03-01-2009, 05:58 PM   #1
chillin05VUE
chillin05VUE is on a distinguished road
chillin05VUE's Avatar
Default Just changed my headlight bulbs
I just changed my headlight bulbs from OEM to Silverstars. What a pain in the rear to remove. Had to buy a special slotted screwdriver to slip down to the lower arm. Then tok forever to pop it loose. Once I got it out, getting the bulb out was simple. Looks like the highbeams can come out without using tools. WTF did GM/ Saturn make the low beams such a pain? Has anyone else had as much trouble changing out their bulbs?
"Remember, if the women don't find you handsome, they should at least find you handy" -Red Green
2005 VUE V6 AWD
chillin05VUE is offline   Reply With Quote
Old 03-01-2009, 07:04 PM   #2
Spazie
Spazie will become famous soon enough
Spazie's Avatar
1993 SC2
Default Re: Just changed my headlight bulbs
I changed the bulbs on our 04 standing in the parking lot of Autozone with no problems at all. IIRC, it was a matter of twist and pull and out it came, similar to the bulbs on my SL2.
You want to talk about a pain to change, try the pop-up lights on the first gen SC2. I've changed mine twice in the ownership of mine and it's a total pain because they have to be unscrewed. They're a sealed beam light. The CHMSL lights are even harder because you have to practically disassemble your trunk to get to them.
Have you 'seen the light' yet with the new bulbs? It never ceases to amaze me how pitiful the OEM bulbs in the VUE were. It's literally like night and day when you go to Silverstars.
13 Chevy Equinox, 46k, built in Spring Hill!
04 VUE 3.5, 196k
99 SL2 Homecoming, 211k
Spazie is offline   Reply With Quote
Old 03-01-2009, 08:49 PM   #3
04Pacific
04Pacific is on a distinguished road
2004 VUE 3.5L
I'll admit it is not the easiest to change but definitely not the worst. My 95 Olds you had to remove both cornering lamps, the grill, and then the headlight to get to the bulbs. It wasn't hard, but kind of time consuming.
The easiest car to replace the headlight bulbs on was my 93 Subaru Legacy. You just reached in, gave a quarter turn and that was that. No removing anything!
04Pacific is offline   Reply With Quote
Old 03-01-2009, 09:25 PM   #4
chillin05VUE
I have't "seen the light" yet, as that the sun is still up here. But, I'm leaving for work earlier tomorrow just to see the difference. I've had the lights since October but never had time to replace them until now. My next just is to replace the chmsl with leds if I can find them along with the regular brake lights. I would do the turn signals but I see that theres a special needed to keep the lights from flashing too fast. Not a big deal but I heard that the unit gets hot and can cause a fire if it sits against anything too long.
2005 VUE V6 AWD
Old 03-01-2009, 11:26 PM   #5
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
I did not see much of an improvement with the Silverstars. They had a whiter color than the OEM lamps.
2006 Black VUE Red Line - Now running iOS 11
Old 03-03-2009, 09:23 PM   #6
DrunkScotsman
DrunkScotsman is on a distinguished road
it was a pita changin out the inside ones , i got some after market 59k for mine , i love the color
Importatlanta FTW!
DrunkScotsman is offline   Reply With Quote
Old 03-04-2009, 01:58 AM   #7
YourMainParadox
YourMainParadox is on a distinguished road
YourMainParadox's Avatar
I just used a regular but long flat head screw driver to replace all my headlights... I went with Silverstar Ultras for a night then to the Street Glow High watt ones then still not much of a difference from stock... then I went to HIDs.
BTW all stock headlights are those crappy yellow ones... besides the HIDs
YourMainParadox is offline   Reply With Quote
Old 03-04-2009, 10:31 PM   #8
hoob
hoob is on a distinguished road
Yes you have to remove the whole head light assembly.
I installed the Ultra II, they were a big improvement. I did had to sand the bulb body down to fit the lamp assembly. (both the high and low beam)
I also replaced my fog lamp bulbs. Now that was a waste. As far as I am concerned the fog lamps are just show. Don't waste your money.
hoob is offline   Reply With Quote
Old 03-05-2009, 05:16 PM   #9
AuraDrvr89
AuraDrvr89 will become famous soon enough
AuraDrvr89's Avatar
2007 AURA XE
At least your bumper doesn't have to be removed, like those of us with Auras...
-Joel
Now: 2009 BMW 328i xDrive, Monaco Blue Metallic
Then:
2007 SATURN AURA XE,Cream White
2004 Saturn Ion 3 Special Edition Sedan, Onyx Black
AuraDrvr89 is offline   Reply With Quote
Old 03-06-2009, 06:34 PM   #10
YourMainParadox
Now that sounds fun
Old 03-06-2009, 07:03 PM   #11
YourMainParadox
Did you take pix of the stock vs the silverstar ultra? That is one thing I forgot to do. Here is the Silverstar Ultra II VS the HID 8,000k.
Old 03-06-2009, 08:05 PM   #12
chillin05VUE
No, I didn't think about it. I should have.
2005 VUE V6 AWD
Old 03-09-2009, 10:50 PM   #13
chillin05VUE
Default Re: Update: Just changed my headlight bulbs
Wow, I've seen the light this morning and I love it!!!!!!!!!!! With the time change, it's dark out when I leave for work now. Didn't know the OEM lights were so bad. The Silverstars are much brighter and whiter then the factory units. Don't know why I waited so long to change them. I'm wondering now that when I change the fog lights, will they be just better then the OEMs. Not sure if I want to go with CoolBlues or Silverstars for them also. What does every else think for the foglights?
2005 VUE V6 AWD
Old 03-10-2009, 02:47 AM   #14
04Vuesilver
04Vuesilver is on a distinguished road
2004 VUE Red Line
stick with the silverstars for the fogs too, keep it all uniform
04Vuesilver is offline   Reply With Quote
Old 03-10-2009, 05:13 AM   #15
YourMainParadox
The cool blue look significantly dimmer when next to the silverstar ultra. I was not very impressed. Tho compared to the HID the silverstars look crappy and yellow :P
Old 03-18-2009, 12:01 AM   #16
xtremeranger
xtremeranger is on a distinguished road
xtremeranger's Avatar
2005 VUE Red Line
2006 ION Red Line
I love my 5000K HID's.....I just need to aim them a lil better...i think both of them are aimed at the same point.....
2005 VUE Red Line AWD - Tint, Audio, K&N
2006 ION Red Line Competition Package - Stage 2, strut bar, Hurst, Antenna delete, tinted corners, painted headlights
1998 SL2 - SOLD 87K-113K
xtremeranger is offline   Reply With Quote
Old 03-18-2009, 03:20 PM   #17
AuraDrvr89
AuraDrvr89's Avatar
2007 AURA XE
Originally Posted by YourMainParadox View Post
Now that sounds fun
Yeah, I'm sure it will be. This is the main reason why I haven't changed my headlight bulbs yet..
-Joel
Then:
Old 03-19-2009, 06:07 AM   #18
YourMainParadox
just replace them with HID's and more than likely never have to do it again :P
Old 03-19-2009, 03:15 PM   #19
AuraDrvr89
AuraDrvr89's Avatar
2007 AURA XE
Good point, but the only way I'd do that is if I were to get projectors... Which gets into tons of money... So, there it is for now. haha
One day..
-Joel
Then:
Old 03-19-2009, 08:02 PM   #20
chillin05VUE
projectors would be so cool. Hoow much are the kits for those?
2005 VUE V6 AWD
headlight bulbs Garrick S-Series Tech 8 03-10-2008 11:55 PM
Headlight bulbs? gordonwd Aura General 6 04-04-2007 09:09 PM
better headlight bulbs, 02 SC2?... SexyMexi02SC2 S-Series General 7 01-19-2005 03:01 PM
Possible to use 2 in one headlight bulbs? ProDarwin Mods and Performance 5 01-21-2003 07:05 PM
headlight bulbs DOHCdude S-Series Mods 7 05-15-2002 08:18 PM
