Old 10-23-2007, 12:59 PM   #1
lentinman
lentinman is on a distinguished road
Default 95 SL1 Motor mount question
With my hood up and the engine running....
.... If someone puts the car in drive (foot on brake, obviously) and then puts it in reverse, the engine shifts (lurches) what appears to be 2-3 inches forward or backward. I have to think it is going to rip something apart sooner or later.
One of my buddies viewing it believed it was probably a broken motor mount which would explain the somewhat noticeable vibration whenever I'm idling.
Q: Does that sound right? And, if so, how many motor mounts are there? Where are they located? Is it likely to be more than one? Can I determine it by viewing? How much would it probably cost? Can I do it myself?
Thanks.
Len
lentinman is offline   Reply With Quote
Old 10-23-2007, 01:47 PM   #2
yazhere
yazhere is on a distinguished road
yazhere's Avatar
Default Re: 95 SL1 Motor mount question
Your issue is frequently advised on this forum.
Use the search with the words mounts or torque axis mount system.
I recommend that the upper engine mount and the lower transmission mount be changed and you will see a large difference in vibration. Both will be about $100 in parts and quite easy to change yourself. Go to youtube.com and search for Saturn mount and you will see video on how to change it. The how-to section in this forum is excellent.
There are two more parts of the system that are struts referred as "dogbones" that are quite resilent however are seen to need replacement sometimes. There is lots of info upon your search.
yazhere is offline   Reply With Quote
Old 10-23-2007, 01:47 PM   #3
saturnhouse
saturnhouse will become famous soon enough
The most likely cause is a broken upper mount. They need to be replaced every so often. Its the one next to the valve cover, outboard on the passenger side - not very expensive, not very hard to do.
saturnhouse is offline   Reply With Quote
Old 11-08-2007, 03:05 AM   #4
lentinman
Thanks for the replies.
I got around to buying and installing the uppper motor mount. It only cost $45 and it only took 20 minutes - thanks to the youtube video.
It made a ton of difference. I realize I could make it even better if I changed the tranny motor mount, but I can't imagine that one being anywhere near as easy.
Len
Old 11-08-2007, 08:14 AM   #5
Phredawgy
Phredawgy's Avatar
Len
Did you do this?
http://www.saturnfans.com/forums/showthread.php?t=73563
If not then do it as soon as you can
Old 11-08-2007, 12:39 PM   #6
Luke
Luke's Avatar
Default Re: 95 SL1 Motor mount & Transmission mount issue
Fm > Len
Fm > Yazhere
I strongly 'second' his recommendation. Both the Upper Engine Mount, as well as the Lower Transmission Mount.
Also, if you want to verify that your upper engine mount is failing,
Upper Engine Mount Measuring for "failing"; 1st Generation design.>Here<.
>>> Picture of Upper Engine Mount, and a way to measure/determine if it is "failing".
>Here<
Luke is offline   Reply With Quote
Old 11-08-2007, 12:49 PM   #7
Phredawgy
Phredawgy's Avatar
>Here<
He's already replaced the Upper Engine Mount......so I am hoping that this part http://www.saturnfans.com/forums/showthread.php?t=73563 was taken care of or gets taken care of soon
2000 SL1 upper motor mount question pimpin88 S-Series Tech 4 03-08-2009 01:21 PM
SL1 Motor mount studs jarl S-Series Tech 5 12-19-2006 02:20 AM
92 Sl1 upper motor mount ?'s johnt671 S-Series Tech 2 10-24-2006 08:55 AM
Saturn 2000 Sl1 Brakes/ motor mount question Wired220 S-Series General 2 10-04-2004 07:27 PM
1991 SL1 Motor Mount/Shock Absorber? coolgreany S-Series Tech 8 01-30-2003 02:29 AM
