Old 10-16-2007, 09:14 PM   #1
93goldsl2
93goldsl2 is on a distinguished road
1993 SL2
Default Can the ignition switch be removed without removing the steering wheel (93 SL2)?
I have the problem with the chime staying on after the key is taken out - seems to be a common one. I've seen some differing information on whether or not you need to pull the steering wheel to get to the ignition switch. Haynes says yes, but I don't see any mention of that in the write up in the how-to section on here. Hopefully it's not needed?...
Thanks!...
93goldsl2 is offline   Reply With Quote
Old 10-16-2007, 10:14 PM   #2
Greg1
Greg1's Avatar
1997 SW2
Default Re: Can the ignition switch be removed without removing the steering wheel (93 SL2)?
On my Gen 2s it's accessible by just removing the covers. I had the same problem when I bought my 97 four years ago and found a post then about taking it apart and slightly stretching the spring. It worked.
97 SW2 5-Sp 273k -mine
Old 10-17-2007, 09:31 AM   #3
richpin06
richpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nice
richpin06's Avatar
This should pertain to your 93.Click here.
Old 10-18-2007, 08:14 PM   #4
93goldsl2
1993 SL2
Awesome - great video, thanks...
Right now I'm stuck because I've lost the right attachment for my narrow drive nut/screwdriver set.... Should get back to it this weekend.
Old 10-19-2007, 11:48 AM   #5
Luke
Luke's Avatar
Default Video submissions
Fm > 93 Gold SL2
And I believe that you'll find that it applies only when the driver's side door is open.
Fm > Rich
And I want to make it perfectly clear, that I am NOT jealous
of your time and efforts over your video submissions.
I am not jealous, I am not jealous, I am not jealous..............
but................thank you..........
Luke is offline   Reply With Quote
Removing steering wheel/horn tallNewfie Astra Tech 1 12-30-2009 02:59 PM
Schematic for removing steering wheel qwikz28 Vue Tech 0 07-31-2009 12:13 PM
Ignition switch assembly loose on steering column tmaugham General Saturn Discussion 1 03-30-2006 12:27 AM
99 SL2- Need to pull steering wheel to R&R ignition switch? purewatersmith S-Series Tech 6 03-10-2006 02:20 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 02:09 AM
