Old 11-12-2018, 03:46 PM   #1
burner1503623
burner1503623 is on a distinguished road
Default 1998 SW2 Carpet From Other Gens??
My 98 SW2 has no carpet in it, at all. My local junkyard has a 99 SW2, a few 96's and 97 SL2's. I was wondering if any of the earlier and older gens and/or models carpet would fit into the 98 SW2.
Add to burner1503623's Reputation
Rate the quality of this post and help burner1503623 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burner1503623 is offline   Reply With Quote
Old 11-12-2018, 04:56 PM   #2
Default Re: 1998 SW2 Carpet From Other Gens??
They all fit fine. 97, 98, 99 will be the best and easiest install.
Old 11-12-2018, 06:20 PM   #3
burner1503623
Awesome thanks OldNuc
Old 11-13-2018, 01:15 AM   #4
After putting a '96 SL2 carpet in a '97 SC1 I say they all fit just fine
Though, to be fair...the 4dr carpet had holes under the front seats for rear foot heaters the 2dr's don't have and the B-Piller cutouts were different but hidden under the trim.
Old 11-13-2018, 07:50 AM   #5
Waiex191
Waiex191's Avatar
Saturns have rear foot heaters?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-13-2018, 10:08 AM   #6
Could be extra intake's for the HVAC but it looked like it was piped into the front foot heater pipes rather than the intake.
Old 11-13-2018, 10:21 AM   #7
trottida
trottida's Avatar
There are HVAC vents routed on the floor through the center console and under the front seats diverting warm/cool air to the rear seat foot wells. Apparently only applicable to sedans and wagons though. I didn't know that.
You can see them in this photo; follow the red arrows.
As a side note; how do you link to a photo in the photo library to use in a post. Credit to username bender for the photo. I had to use the Snipping Tool to put it in this post.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 11-13-2018, 10:56 AM   #8
You'll have to either disable Javascript or gather a bunch of us to beg Charlie to enable it on his end. Given the cost of bandwidth I understand why he has it disabled, but there ought to be a way to enable it just for this site (similar to Photobucket's hotlinking ban).
Old 11-13-2018, 06:13 PM   #9
burner1503623
Thats what those are! haha. Always wondered that. Are the seats a breeze to remove? I know they are on rails so they have springs I assume.
EDIT* I assume if the seat is alway the way forward its safe to remove then?
Old 11-13-2018, 07:30 PM   #10
trottida
trottida's Avatar
Each front seat is held in with four E10 bolts and you have to disconnect 1 electrical connector (seat belt sensor) on the drivers side. Use the right socket as once you round out the head it's difficult to get the bolt out as there's not that much material there to work with. You can remove them all the way forward or in any position as long as you don't engage the fore/aft position lever while they are out. Even at that it not too big a deal. I usually remove the rear bolts, push the seat back and then remove the front bolts. I do it this way so the rails aren't sticking out and removal from the car is easier.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 11-14-2018, 11:01 AM   #11
One some of the coupes, you have to slide the seat belt out of the presenter arm (on my 3rd gen, it is attached to the headrest leg).
I always forget, and try to pull the seat out only to have the belt stop me
Old 11-14-2018, 07:18 PM   #12
burner1503623
Would I have to swap the rails? If say it was a 96,97,98,99 seat into the 98 wagon. Or can I leave the rails alone by chance?
Old 11-14-2018, 07:19 PM   #13
burner1503623
Thank you for the info about the E10 bolt. I looked at them the other day and thought what the f...
Thankfully the socket is cheap.
Old 11-14-2018, 07:32 PM   #14
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
The rails are apart of the seat
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Old 11-14-2018, 08:14 PM   #15
trottida
trottida's Avatar
The seat is bolted to the car through the rails. All rails are the same between Sedan, Wagon and Coupe; all generations 91-02.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 11-14-2018, 08:14 PM   #16
burner1503623
Okay! Thanks
1st Gens cgg17 S-Series General 11 06-02-2017 09:41 AM
1998 Saturn SL carpet kit? ktulu909 S-Series General 8 10-28-2010 03:16 PM
1998 sl2 carpet replacement scottb022563 S-Series General 17 02-09-2009 09:02 PM
1998 sl2 carpet replacement scottb022563 L-Series General 1 02-06-2009 04:00 PM
1st & 2nd gens post your pics of 1st & 2nd gens saturncrzy S-Series General 9 06-13-2008 09:33 AM
