Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 08-26-2014, 01:47 PM   #1
Blv198909
Blv198909 is on a distinguished road
2007 ION-2 Quad Coupe
Default Questions about the 2.4 intake mani. and tb swap on a 2.2
I am looking to do the mod, but curious as to what all gains and losses ill achieve from it, and if a tune is required, or would a remap suffice in place of the mod.
Add to Blv198909's Reputation
Rate the quality of this post and help Blv198909 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Blv198909 is offline   Reply With Quote
Old 08-26-2014, 08:53 PM   #2
ruley73
ruley73's Avatar
Default Re: Questions about the 2.4 intake mani. and tb swap on a 2.2
I've also been looking into doing this myself. Most of the info I learned I got from Cobalt forums. So whenever I say "they" that is who I'm referring to.
They indicate that it is a worthwhile mod even without getting a tune. Most of the Cobalt folks say the most HP gain is achieved with an older 2006-2007 LE5/2.4L intake manifold (p/n 12587878), an older LE5 2.4L throttlebody (p/n 12580195), and a tune. They claim that the 2008-2011 LE5/LE9 2.4L intake manifold (p/n 12597953) doesn't flow quite as well as the older one, but no one seems to know how inferior it really is. I posted a picture of the two below.
The catch is that a brand new older LE5 intake manfold costs $450-500 while the newer one is only $100-$150 depending on where you purchase it from. The older intake seems to be hard to find used from a eBay or a junkyard.
The 2.4L intake manifold by itself is a direct bolt-on swap for 2007 Ions, but a throttlebody adapter (like this one from CBM Motorsports) is required for 2003-2004 Ions. I believe the same throttlebody adapter is also required for 2005-2006 Ions, but someone else will need to confirm this. For all Ions, the power brake booster vacuum hose needs to be extended. On the 2.4L this hose connects to an elbow just below the throttlebody on the front of the intake manifold instead of connecting on the underside of it as on the 2.2L intake manifold.
I don't know the exact amount of gain that is expected. A very rough guess would be about 10HP for the intake alone, 15 HP for the TB & IM, and 25 HP for the TB, IM, and tune altogether. A better flowing exhaust (and 2007 exhaust manifold for 2003-2006 Ions) should yield even greater gains.
There is at least one other member (TexasGunslinger I think?) that has completed this mod.
2007 Ion 2 Quad Coupe 5-speed manual 179K miles
2007 Chevy Equinox LT 190K miles
Add to ruley73's Reputation
Old 08-27-2014, 02:15 PM   #3
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
id like to look into doing this also. i know i cant do the tune, but since your saying it can be done without a tune, give me another option for more power.
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-27-2014, 07:26 PM   #4
Blv198909
Thank you! this was pretty much exactly what I was looking for,and its good to know I can do this right away and get a tune not to long after. Once I do start this mod ill upload pics and info on it here.
Old 01-01-2015, 05:13 PM   #5
Blv198909
Will a 2006 hhr 2.4 manifold work also part number 12602735?
Old 01-01-2015, 11:27 PM   #6
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
i think the hhr also use ecotechs, so it should
03 ion-2 Sedan 5sp
♕KCCO
Old 01-02-2015, 01:18 PM   #7
goaliemo
goaliemo is on a distinguished road
2003 ION-1 Sedan
2006 ION Red Line
The 2.4 in the HHR is the LE5 ecotec.
I'm just a guy that enjoys my Ions.
Try Google, first. Then ask.
Add to goaliemo's Reputation
Rate the quality of this post and help goaliemo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goaliemo is offline   Reply With Quote
Old 01-02-2015, 02:26 PM   #8
ruley73
ruley73's Avatar
I don't think that intake was originally installed on that HHR. That part number is a variant of the 2008 and newer intake that I posted a picture of in my previous post. It will still work fine.
Old 01-02-2015, 05:02 PM   #9
Blv198909
Here's A photo of the intake I pulled off a hhr in a salvage yard. It looks like the older one.
Old 01-03-2015, 05:13 AM   #10
ruley73
ruley73's Avatar
i am definitely wrong. There is no doubt that is the early design. I was going off of a picture someone posted in another forum that referenced the same part number. Is 12602735 the part number that is actually stamped on the intake?
Old 01-03-2015, 03:01 PM   #11
Blv198909
948686894 is the other set of numbers in it, and when I look it up, I hardly get any results, and I just got the new gaskets in so I should be uploading photos of it later today.
Old 01-05-2015, 12:17 AM   #12
ruley73
ruley73's Avatar
I've also been thinking about doing this mod. Do you have a different air intake or are you using the stock airbox/filter housing?
Old 01-05-2015, 09:36 AM   #13
Blv198909
Right now using the stock air filter set up, but will probably go to an aftermarket application. The 2.4 intake seemed to cramp up the space for it. I also ran into a slight issue with the map sensor, had to do slight modification to get it to work, but plan to properly do it next week. The other issue I ran into is that when I downshift the engine seems to want to stay at the current revs and not go down for a few seconds, I believe this could be cause of the map sensor or a throttle body issue. Other then that, this mod was a breeze, just call a parts store ahead of time to get the gaskets for the 2.4 intake.
Old 01-05-2015, 01:04 PM   #14
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
the constant reving is caused by the maf sensor on the intake.
the car will rev up, and nearly stay where it reved up, or go down to 1500rpm but no lower.
I know when mess with my intake (using the spectre intake, where you piece together different sections), since there isn't a piece that is properly made to mount the sensor, if not inserted or positioned correctly, it will cause rpms to stay above 1500rpm.
03 ion-2 Sedan 5sp
♕KCCO
Old 01-06-2015, 02:24 PM   #15
Blv198909
here is a pic of the stock air filter set up, like I said its become a tad cramped now,so I will be running a after market application in the near future.
Old 01-15-2015, 07:22 PM   #16
dylanbutler
dylanbutler is on a distinguished road
so whats everything needed to do this mod?
Add to dylanbutler's Reputation
Rate the quality of this post and help dylanbutler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dylanbutler is offline   Reply With Quote
Old 01-15-2015, 10:28 PM   #17
ruley73
ruley73's Avatar
I'm quoting someone else, but.... "Wow, you fail hardcore at reading."
All the info you need is in this thread. If you have a 2003-2004 2.2L you will also need a throttlebody adapter.
Blv198909, did you notice much power & fuel economy difference without a tune?
Old 01-16-2015, 04:29 AM   #18
Blv198909
I have noticed a somewhat increase with power in the mid range, I plan to go get the throttle body and a wire harness for the map sensor that came with the manifold cause the 2.2 took a bit of tinkering to work,and with fuel I may be using a tad more, but I can't really say cause I have a lead foot. I plan to get a tune done once I get my headers ordered and installed. Here is a pic o the map sensor. I'm going to try and see if I can use the wire harness from the 2.4 map and use it on the 2.2 instead, cause making a part fit will only work for so long.
Old 07-10-2015, 03:15 PM   #19
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
bringing back an old thread.
would swapping the 2.2 TB with an LSJ TB make any difference.
and would having the LSJ TB still require the adapter plate?
i want to the 2.4 swap, but am hoping to avoid having to get the plate by seeing if an LSJ TB would require one or not.
if i have to, ill just get the adapter plate
03 ion-2 Sedan 5sp
♕KCCO
Old 07-10-2015, 03:22 PM   #20
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
Both require the plate.
Going to look at a DOHC. questions questions for the swap. RBrown20 S-Series Mods 7 03-16-2009 07:53 AM
92 OEM DOHC Mani on a 94 SL2 94SLow2 S-Series Mods 14 03-24-2007 02:12 AM
92 exaust mani the_skin_eater Classifieds 7 05-16-2005 12:04 PM
FS: 00+ Headlight, 99 Intake Mani+TB, 00+ DOHC Guages,Digital Camera Sprint Classifieds 4 05-03-2005 08:16 PM
intake swap sierrap615 S-Series General 2 04-04-2004 09:36 PM
