Old 06-14-2018, 01:39 PM   #21
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Default Re: Code P0301 Troubleshooting
Originally Posted by wolfman View Post
I have seen a recent upswing in the number of folks getting SES lights that reveal the P301 code when scanned. (Misfire) I will toss this out as a quick "general" troubleshooting guide with TWO senarios:
Senario #1.
Upon initial start up, cars runs/idles very rough, though usually sometimes only briefly, and SES light comes on. (Code P0301 generated)
In this senario, odds are that a problem exists in the IGNITION system somewhere. Things to check:
1. Spark plugs (non platinum, correct gap)
2. Spark plug wires (cross firing due to age and moisture or oil flooded plug wells in the DOHC engines only)
3. Coil pack towers (corroded)
4. Coil pack to engine bolts corroded at loop connectors
Senario #2.
Car starts and idles ok, cruises ok, but stumbles, jerks and or "misses" during moderate acceleration or hill climbing, and SES light comes on. (Code P0301 generated) In this senario, odds are that a problem lies in the FUEL or EGR system despite what the code suggests. A fault in one of those other two systems may be leaning out the air fuel mixture briefly and causing the misfire. Things to check:
1. Fuel injectors clogged
2. EGR valve sticking
3. MAP sensor vacuum ports clogged/leaking or poor electrical connection
4. Faulty TPS or TPS wiring/connector
5. Items 1-4 in senario 1 (just to be sure)
So you dont think it could be loss of compression in cylinder 1 because of mechanical wear?
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Help troubleshooting a P1404 Code Froz S-Series General 9 04-27-2017 08:57 AM
01 SL2 Code P0301 guzzel S-Series General 8 08-04-2009 06:33 PM
P0301 Question BarnOwl S-Series Tech 7 06-04-2008 08:13 PM
Sat SL1 P0301 CODE ROUGH IDLE docusn1 S-Series General 4 12-17-2007 07:30 AM
OBD Code: P0301 Cylinder 1 Misfire Detected hc803 S-Series Tech 16 01-22-2007 11:25 AM
