Old 07-20-2004, 08:00 AM   #1
04SilverVue
04SilverVue is on a distinguished road
04SilverVue's Avatar
2004 VUE 3.5L
Default Power Outlet on Vue....
OK as I was going to work this morning I came into the dark garage and before I touched the key fob to open the door I noticed that my Radar Detector (I just started using it) was on! In my old car I could always leave it plugged in and it would turn off when the car was off. It seems the Vue supplies constant power to it. I am lucky that I had enough juice to start my car considering I have had it plugged in for 4 days now! Why would they not have it turn off with the car? It is a pain to have to un-plug it everytime I get in and out of the car. But has anyone else noticed this?
04SilverVue
DFW, Texas
Add to 04SilverVue's Reputation
Rate the quality of this post and help 04SilverVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
04SilverVue is offline
Old 07-20-2004, 08:04 AM   #2
BlueDevil
BlueDevil is on a distinguished road
BlueDevil's Avatar
Default
yeah, my cell phone keeps charging when i shut the car off. i like that though.
Add to BlueDevil's Reputation
Rate the quality of this post and help BlueDevil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlueDevil is offline
Old 07-20-2004, 08:35 AM   #3
Skuterdude
Skuterdude is on a distinguished road
Skuterdude's Avatar
Default
Since the fairly recent explosion of cell phones, manufacturers are wiring the lighter so they are hot all the time......15 years ago they were not.....
rewiring it through the key would not be a big job......
2004 VUE AWD Honda V6
Add to Skuterdude's Reputation
Rate the quality of this post and help Skuterdude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Skuterdude is offline
Old 07-20-2004, 08:54 AM   #4
revue
revue is on a distinguished road
revue's Avatar
Default
I don't use the power outlet. My detector is windshield mounted on the
drivers side of the vehicle above the VIN tag. It's less visible there
and drivers behind me can't see it. I had to bend the mounting bracket
a bit because the windshield is curved at that point. I removed several
plastic panels below it and ran the power cable(non-coiled type) down
and over to the fuse block and connected it to the heated seat fuse with
one of those adapt-a-fuse gizmos. I don't know why my vehicle even had
the heated seat fuse because I don't have them, but that circuit is only
hot when the engine is running. I disconnect and hide the detector in
the small bin under the steering column when parked in public lots.
04 V6's should come with a factory radar detector!!
Add to revue's Reputation
Rate the quality of this post and help revue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
revue is offline
Old 07-20-2004, 09:00 AM   #5
KJB
KJB is on a distinguished road
KJB's Avatar
Default
Same here.
Add to KJB's Reputation
Rate the quality of this post and help KJB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KJB is offline
Old 07-20-2004, 09:42 AM   #6
04SilverVue
2004 VUE 3.5L
Default
If I get a good radar detector like the one I want (Valentine 1 V1) then I might hard wire it like this but my cheapo just isn't worth all that. It is like 10 years old! I just use it because they started settin speed traps close to work recently.
04SilverVue
DFW, Texas
Old 07-20-2004, 10:37 AM   #7
cdp326
cdp326 is on a distinguished road
cdp326's Avatar
2007
Default
if they come out w/ an updated Valentine One, will they call it Valentine Two?
"It's a car. We've invented the Pontiac Aztek."
Add to cdp326's Reputation
Rate the quality of this post and help cdp326 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cdp326 is offline
Old 07-20-2004, 10:46 AM   #8
04SilverVue
2004 VUE 3.5L
Default
Probaby Valentine One V2 because the Valentine One V1 in the current model.
04SilverVue
DFW, Texas
Old 07-20-2004, 10:53 AM   #9
bk63
bk63 is on a distinguished road
Default
I put a lighted switch next to my right leg in the panel inline with the 12 volt outlet. Reason is my cell charger fits so tight into the socket I don't want to plug it in and pull it out all the time. It has led's on it, not that that's much of a drain, but now I can plug in my phone for hands free/charging use while I'm driving, and now shut off the power to the outlet when I get out.
Add to bk63's Reputation
Rate the quality of this post and help bk63 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bk63 is offline
Old 07-20-2004, 12:08 PM   #10
ltank
ltank is on a distinguished road
Default All GM built vehicles stay on
All GM built vehicles maintain plug power when the switch is off. They have as long as I can remember(early 70's). The Japanese vehicles cut power to the cig lighter when switch is off. The GM clones built (designed) outside of GM are the same as their original manufacturer or planner(ex. Pontiac Vibe, Geo Prizm cut-off like Toyota). Don't worry about your detector killing your battery. I drive my Suburban once or twice a month, and the detector as never even produced a weak battery, and it's never off.
Add to ltank's Reputation
Rate the quality of this post and help ltank reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ltank is offline
Old 07-20-2004, 01:07 PM   #11
SaturnVue'03
SaturnVue'03 is on a distinguished road
Default
Don't have that problem in Virginia where radar detectors are illegal...
Add to SaturnVue'03's Reputation
Rate the quality of this post and help SaturnVue'03 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnVue'03 is offline
Cigarette Outlet Power joshrp5 Vue Tech 18 07-04-2009 10:55 PM
Power Outlet jwpaton Vue General 2 11-02-2008 10:26 PM
power outlet!?! B|o|B|o 2008 Vue 6 10-29-2007 10:28 PM
power outlet Jeff Berry Aura General 3 06-15-2007 09:07 AM
power outlet in VUE wei_ Suggestion Box 0 01-12-2001 06:08 PM
