Old 06-15-2008, 08:22 PM   #1
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
Post Aura Intake Resonator Bong Delete
With the lack of cold air intake options available to Aura owners, many people are wondering what they can do to free up the air flow to their engine and give it a big of a larger bark at the same time, like a CAI would do. Well the answer to this is simple, and not that much different than an actual CAI, anyway - remove the intake resonator bong.
"What is it?" you ask? Simply put, it's a piece put in place by OEM manufacturers to mute the engine noise - hence the name "resonator." There's really no other purpose for it. So by removing it, you remove a restriction of air flow into the engine, and also allow for more sound to be heard from your engine. Likewise, most CAI systems come with a new filter, usually a wire-mesh design (vs the paper type of most OEM filters) which also allows for more free-flowing air, but also filters the air just as well as they use an oil-based coating (which needs to be "recharged" every once in a while) to grab the dirt particles out of the air.
So, let's get on with removing this hassle now!
Engine @ idle before:
1) Jack up the front-right of the car - enough to remove the front right wheel.
Make sure to use the correct spot for supporting your car, or you will bend the frame. You'll know the first one or two pumps after connecting if it's the right spot - if the car goes up, you're good, otherwise you'll see the jack sink right into the metal
2) Remove the wheel well shroud.
This is done by removing a myriad of plastic "screws" along w/ standard 7mm screws that hold this large piece of plastic in place. It's there to prevent water & debris from getting up into the metal of the frame and into the air filter as well. You'll want to just keep removing plastic & metal screws as you find them holding this piece in place. Here are a few of the ones you're looking for
Along w/ the ones on the outer edge that you see here, there are also 3 plastic and (at least) one standard screw that hold a piece of this shroud up under the front bumper. As i said, as you start removing them and try to take the shroud out, you'll easily be able to pinpoint where there are more holding it in.
Keep in mind that this shroud is durable plastic, so pulling hard, coaxing w/ a hammer, etc won't hurt anything as long as you're smart about it. This shroud does tuck into the exterior body molding above the wheel, so you'll have to get it out of that first for it to even come close to coming out. Likewise upon reinstallation this is the first step to getting it back in.
3) After you get the shroud out, the resonator bong will be staring you right in the face along w/ a single screw holding it in.
This should be evident as to just how menial this piece really is to the whole setup
The 10mm screw here needs to be removed, and then you just need to use some brute force to release the plastic "rivet" that holds the front portion of the resonator in place. People who worked on Ions are more than familiar w/ these rivets, but the problem here is that there's not a damn bit of light that reaches the rivet up front to see how to get it out "properly." So some heavy coaxing by prying / levering w/ a pliers is what I used. It does nothing but hold the bong in place, so the empty, somewhat beat up, hole that's left over is of no consequence.
Note You can see after removing the bong that NOTHING is affected as far as the risk to the engine. The inlet to the air filter is actually higher so there's an even less chance of taking on water, and it's still before the filter, so there's no more chance of getting debris into the engine.
4) Put the shroud back in, wheel back on, and lower the car.
5) Purchase a K&N (or similar) air filter to go into the stock air box, installation is straightforward. Remove the two metal clips at the top (closest to the windshield, visible in the first video in this post) side of the box above the filter and pull up on the top portion. It flexes easily to allow access to the filter.
6) Enjoy! Most people who have done this mod, or installed a CAI in a car, will tell you the first couple of things they notice are the sound and the better throttle response.
After videos:
Engine @ idle
Revving
thanks for reading, hope you enjoy! (+rep appreciated )
+rep always appreciated!
The Procharged Ion - http://kickassion.bc3tech.net
16.317s @ 85.30mph (Nearly stock)
188.28whp / 175.03wtq - SMP Stage 2 - 10psi
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
Old 06-16-2008, 12:11 AM   #2
bulld0g
bulld0g is on a distinguished road
bulld0g's Avatar
2007 AURA XR
Default Re: Aura Intake Resonator Bong Delete
nice straight forward write up
Add to bulld0g's Reputation
Rate the quality of this post and help bulld0g reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bulld0g is offline   Reply With Quote
Old 06-16-2008, 01:27 AM   #3
Phaeton Driver
Phaeton Driver will become famous soon enough
2007 AURA XR
This was a great write up. Easy to follow.
I have enough trouble just posting a picture on this forum, but you even linked to video with sound. Your a master at this stuff for sure.
Thanks a ton for doing it.
Add to Phaeton Driver's Reputation
Rate the quality of this post and help Phaeton Driver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phaeton Driver is offline   Reply With Quote
Old 06-16-2008, 08:34 AM   #4
Johnny84
Johnny84 is on a distinguished road
Johnny84's Avatar
2008 AURA XE
2009 VUE 3.6L
Great How-To!
You put this together better than I could have. Nicely done!
Add to Johnny84's Reputation
Rate the quality of this post and help Johnny84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Johnny84 is offline   Reply With Quote
Old 06-16-2008, 09:17 AM   #5
bc3tech
bc3tech's Avatar
2007 AURA XR
Attention Re: Aura Intake Resonator Bong Delete
I forgot one last step (and restrictions in effect on this board don't let me edit posts after a certain time )
7) When finished and everything sounds good, you need to reset your fuel trims. You can do this via a device like the DashHawk or you can simply leave the negative terminal of your battery unplugged for about 20-30min.
This takes the "learned" fuel trim (amount) readings that your car has developed over time and resets them so that in the next few miles it will re-learn how much fuel the engine needs in various conditions. This is needed because now the air will be getting a different amount / "quality" of air into it, so the fuel needs will change slightly. This isn't a requirement for this modification, per se, but as a general rule whenever you change something that alters the air / fuel input to the engine, you should perform this operation.
Old 06-16-2008, 09:44 AM   #6
Gerry Proctor
Gerry Proctor has a spectacular aura aboutGerry Proctor has a spectacular aura about
2008 Astra XR
2008 SKY Red Line
You might have to do that if you had a fuel system error in the long term fuel trim or a fault in baro that kicked the fuel table way out of whack. The O2 sensor is responsible for adjusting the short term fuel trim and reacts instantaneously. This is how you can drive your car from the beach to the mountains without having to adjust anything. If the short term trim is continuously deflecting + or - 20 percent, the computer will select a different fuel table in the long term fuel trim.
Also, disconnecting the battery for 20 minutes does nothing. You need to deplete the stored energy to kill the keep alive memory. You do this by removing the negative cable and stepping on the brake pedal five times, or hold the disconnected negative cable to the positive cable for those five times.
Finally, while removing the "bong" creates more intake noise (which gives you the sensation of more performance), it does nothing for performance or at least no more than tribal graphics would give you. No air flows through the bong and if no air flows through it, it can't possibly be a source of flow restriction. It creates an inverse sound wave based upon the air flowing past it and resonates that wave back into the intake to cancel the sound.
Add to Gerry Proctor's Reputation
Rate the quality of this post and help Gerry Proctor reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gerry Proctor is offline   Reply With Quote
Old 06-16-2008, 11:27 AM   #7
cverstij
cverstij is on a distinguished road
cverstij's Avatar
2007 AURA XR
2008 VUE 3.5L
Thanks, buzzkill......
Add to cverstij's Reputation
Rate the quality of this post and help cverstij reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cverstij is offline   Reply With Quote
Old 06-16-2008, 12:41 PM   #8
bc3tech
bc3tech's Avatar
2007 AURA XR
Roll Eyes Re: Aura Intake Resonator Bong Delete
correct, but your long term trims will need adjustment and rather than waiting for countless miles to be compounded upon the already-calculated trims, it's quicker to reset them to 0 and have them learned w/ the new setup straight-away. the STFT's are an adjustment on top of the LTFTs which are calculated over a much larger sample size, resulting in a larger "wait time" for them to adapt to changed engine conditions.
Also, disconnecting the battery for 20 minutes does nothing...
according to my DH, disconnecting the battery cable for this amt of time resulted in LTFT's of 0 upon startup, prior to that they were valued.
hence why this is usually (and ideally) coupled w/ a change to a K&N-style intake filter; which does allow more air flow
...No air flows through the bong and if no air flows through it, it can't possibly be a source of flow restriction...
where is the inlet for the intake then? looked to me like the bong connected right up beneath the filter, where the air would come in, and for the bong to create a sound wave inverse to what is going past it, wouldn't the inlet on the bong need to have some air going past it? parked right up behind the front bumper doesn't seem like an optimal place for getting air PAST an opening.
Old 06-17-2008, 06:38 AM   #9
snobrdrdan
snobrdrdan is on a distinguished road
snobrdrdan's Avatar
2009
2007 ION-3 Quad Coupe
I think he meant that air doesn't exactly flow into the bong, but that it's sucked in thru the intake by the engine
But then again, that doesn't make much sense either because with air being sucked in....that means air is flowing thru the intake
So maybe he should better clarify, LOL
Nice post though!!! (was finally able to see the pictures)
2009 VW GTI
FRO: 2007 Ion REDLINE -- 8/06-3/08
2008 Aura XR -- 3/08-8/08
Add to snobrdrdan's Reputation
Rate the quality of this post and help snobrdrdan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
snobrdrdan is offline   Reply With Quote
Old 06-18-2008, 01:44 AM   #10
Phaeton Driver
2007 AURA XR
What the heck can stepping on the brake pedal do with the negative battery cable removed do? If there were any capacitors holding a voltage or flash memory with data stored, with the negative terminal open, there still wouldn't be any discharge as far as I can figure.
So how does this procedure do anything to the memory?
TIA
Old 06-20-2008, 08:19 PM   #11
B.A.S.S.
B.A.S.S. is on a distinguished road
B.A.S.S.'s Avatar
2008 AURA XR
Does this go for cat-back exhaust enlargement and free-flowing exhaust swapping? I did it probably 4 months ago, so the fuel trim would of adjusted by now anyways, right?
#@ck yaa, it's a SATURN
Add to B.A.S.S.'s Reputation
Rate the quality of this post and help B.A.S.S. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
B.A.S.S. is offline   Reply With Quote
Old 06-22-2008, 04:55 PM   #12
mrwerner22
mrwerner22 is on a distinguished road
mrwerner22's Avatar
2007 AURA XR
2002 VUE 3.0L
4 months ago, you're perfectly fine. its all adjusted a while ago.
2007 Aura XR... NICE
Add to mrwerner22's Reputation
Rate the quality of this post and help mrwerner22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrwerner22 is offline   Reply With Quote
Old 07-25-2008, 12:33 PM   #13
bc3tech
bc3tech's Avatar
2007 AURA XR
sorry i didn't get to this post until now.
it definitely applies to those kinds of mods. You're flowing more air through the whole system, so you want the car to know the proper fuel. it has probably adjusted by now, but resetting your fuel trims (either by a programmer like the dashHawk or by disconnecting the battery) is a good idea whenever anything drastically changes with your atmosphere or the airflow to your engine. i do it between fall & winter, and winter & spring, and also if i travel to a drastically different altitude and plan on staying there for any longer than a couple of days.
Old 07-25-2008, 08:42 PM   #14
B.A.S.S.
B.A.S.S.'s Avatar
2008 AURA XR
Thanks. I went ahead and removed the resonator bong about 3 weeks ago, and have been tempted to add a post. So here it is.
It only took me 20 minutes to do. It was easy. It did nothing. I went ahead and disconnected the negitive terminal of the battery, and grounded it to the positive post for a half hour also. Also swapped the air cleaner to a K&N. Still makes no increased nothing. A waste of time. And now there is a easier way for water to get into my intake,... if I decide to drive through a levy breach.
Any way, I say don't waste your time SaturnFans, if you're thinking about it. I also say if you want what was touted at the begining of this post, then do what I have already done, and it is the favorite mod that I have done to my Aura. Remove the stock exhaust system from the Cat back and replace with a 2 1/2" pipe and add a Magnaflow resonator and Magnaflow muffller. You WILL get the added H.P.(a few), you WILL get the added racing sound effects, and you WILL still wish you had a V8 when that Porche Turbo blows your doors off on the 405 at 1 in the morning. Whoops,....I sounded cool though!
http://www.saturnfans.com/forums/sho...d.php?t=118792
Old 07-26-2008, 06:20 PM   #15
bc3tech
bc3tech's Avatar
2007 AURA XR
...It did nothing. I went ahead and disconnected the negitive terminal of the battery, and grounded it to the positive post for a half hour also. Also swapped the air cleaner to a K&N. Still makes no increased nothing. A waste of time. And now there is a easier way for water to get into my intake,... if I decide to drive through a levy breach.
maybe you didn't pay attention to where your the hole to your intake was before, and where it is now. it's actually about 2-3" HIGHER than it was before, so if you want to ***** about that angle, you should ***** harder about the stock setup.
i have never heard exhaust mods yielding better throttle response - since that, and the sound, were what was "touted" in the first post here
do you have any proof backing up your statement or are you simply going by your butt dyno to attack somebody's mod suggestion? what was the cost of your mod list vs what was outlined here? would you care to post a how-to for it? nobody's ever denounced the validity of exhaust mods, this thread was in response to the lack of CAI options - which something tells me you'd have spent the money on and installed if it were available, and told everybody it was awesome - when in reality it's no different than what's been outlined here.
i must say i used to view you with respect on this board but that was clearly mis-placed.
btw, if you're panties are in that big of a bunch for it not doing anything and being "more prone" to hydrolock, put it back on in another 20 minutes.
Old 07-29-2008, 06:16 PM   #16
AuraDrvr89
AuraDrvr89 will become famous soon enough
AuraDrvr89's Avatar
2007 AURA XE
Can I assume the same could be done to my Aura 3.5, bc3tech? I don't know how much I'd like to but it might be cool
-Joel
Now: 2009 BMW 328i xDrive, Monaco Blue Metallic
Then:
2007 SATURN AURA XE,Cream White
2004 Saturn Ion 3 Special Edition Sedan, Onyx Black
Add to AuraDrvr89's Reputation
Rate the quality of this post and help AuraDrvr89 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AuraDrvr89 is offline   Reply With Quote
Old 07-30-2008, 10:45 AM   #17
bc3tech
bc3tech's Avatar
2007 AURA XR
i doubt the engine configuration would be that different. in general the process would be the mostly the same, or close enough to deduce, if not identical
Old 07-30-2008, 02:16 PM   #18
AuraDrvr89
AuraDrvr89's Avatar
2007 AURA XE
Yes, it was a thought process of mine. Also considering that the airbox and location looks similar if not identical.
-Joel
Then:
Old 07-30-2008, 05:29 PM   #19
Johnny84
Johnny84's Avatar
2008 AURA XE
2009 VUE 3.6L
Removing the intake resonator on a 3.5 is the exact same process as on a 3.6. From what I can tell it should be the same for the 2.4 as well. From what K&N's website is saying all three engines accept the same air filter (Part #33-2249). Someone correct me if they have more info on the 2.4 resonator.
I removed the resonator on my 3.5 and I'm happy with the results. Its cheap and makes a noticeable difference.....why not do it?
Now: 2008 Saturn Aura XE, 3.5L V6, Cream White
Then: 2000 Pontiac Grand Am GT, 3.4L V6, Silver
Old 08-14-2008, 01:53 PM   #20
m_sparks79
m_sparks79 is on a distinguished road
m_sparks79's Avatar
2007 AURA XR
I just removed mine last night. Like stated before it's cheap, only costing a few minutes of your time, and you can tell a slight difference. A difference both in sound and slightly in performance. This will be good enough until I get the funds for this http://cgi.ebay.com/ebaymotors/05-06...spagenameZWDVW Its for the G6, but sometimes you have to think outside the box. Should work and seems like the best option out there, besides custom making your own.
Shane
2007 Aura XR
Current Mods:
- Window tint - Grille chrome - Charcoal 18" G6 Wheels - Blacked out taillights -
Add to m_sparks79's Reputation
Rate the quality of this post and help m_sparks79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
m_sparks79 is offline   Reply With Quote
vue resonator delete joaca 2008 Vue 6 01-13-2009 12:55 PM
intake resonator mkapp S-Series General 5 01-01-2006 01:58 AM
Air intake..."bong or no bong" 05vueblue Vue General 2 09-11-2005 01:59 PM
Took off the intake resonator... Rob1998SL2 Mods and Performance 16 06-29-2003 09:20 PM
intake resonator ProFighterQ Ion General 3 03-26-2003 04:49 PM
