Old 12-01-2014, 07:37 AM   #1
crkeehn
crkeehn will become famous soon enoughcrkeehn will become famous soon enough
2005 RELAY-3
Default Front Power Outlet - Saturn Relay
My front power outlet has stopped working, I suspect it may be a blown fuse. I'm unable to identify which fuse serves the front power outlet. Which fuse protects the front power outlet?
Add to crkeehn's Reputation
Rate the quality of this post and help crkeehn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
crkeehn is offline   Reply With Quote
Old 12-24-2016, 04:26 AM   #2
paultru724
paultru724 is on a distinguished road
Default Re: Front Power Outlet - Saturn Relay
Same like mine.
Add to paultru724's Reputation
Rate the quality of this post and help paultru724 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paultru724 is offline   Reply With Quote
Old 12-27-2016, 05:37 AM   #3
paultru724
Dizzy Re: Front Power Outlet - Saturn Relay
Still can't get the solution.
[url=http://tinyurl.com/192admin]192.168.1.1[/url]
Old 12-27-2016, 04:22 PM   #4
Tried pulling one fuse at a time to see which one is blown? If not labeled as 'cigar' fuse then 'auxiliary' or 'pwr outlet', between 20-30 amps.
Old 12-28-2016, 12:55 PM   #5
crkeehn and paultru, if your owner's handbooks are anything like mine you should be able to find a section in it telling you where all fuse blocks are located along with the fuse and relay labeling and locations on each block.
307,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 05-01-2017, 09:32 PM   #6
henryr79
henryr79 is on a distinguished road
2007 RELAY-3
Have you checked both fuse panels? There is one under the hood near the battery and one in the right end of the dash, you have to pull a cover panel off to get to this fuse panel.
Add to henryr79's Reputation
Rate the quality of this post and help henryr79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
henryr79 is offline   Reply With Quote
1995 Saturn TC not getting power to fuel pump relay Petesshop S-Series Tech 5 06-19-2012 03:08 PM
No power in outlet strider General Saturn Discussion 1 06-06-2011 02:47 AM
Front Power outlet (cigarette) Sharti Vue Tech 4 12-29-2006 03:47 PM
Power Outlet on Vue.... 04SilverVue Vue General 10 07-20-2004 02:07 PM
power outlet in VUE wei_ Suggestion Box 0 01-12-2001 07:08 PM
