Go Back   SaturnFans.com Forums > Categories > Classifieds
Old 06-16-2005, 09:12 AM   #1
etbardensc2
etbardensc2 is on a distinguished road
2004 ION-2 Quad Coupe
Default Looking for 2001 sc2 headlight assembly...
Hi,
I'm looking for a 2001 SC2 DRIVERS SIDE headlight assembly. Yes my current one has moisture in it. Otherwise I might just try drillin holes on the bottom of the assembly.
Thanks
Edward
etbardensc2 is offline   Reply With Quote
Old 06-17-2005, 07:03 AM   #2
juggaloenforcer
juggaloenforcer is on a distinguished road
Default Re: Looking for 2001 sc2 headlight assembly...
I had the same problem wit my passenger side. I just removed it for a couple of days. I let it air dry, then used a hair dryer. Afterwards I used some clear RTV sealent, and went around the edge. So far it has worked for about two weeks, through a couple of good storms. You can also try www.saturnautosalvage.com or www.6thplanetusedparts.com
juggaloenforcer is offline   Reply With Quote
an update on the 2001 SC2 headlight water greencoupe02 S-Series General 6 09-23-2011 12:41 AM
How do I replace the Headlamp assembly in a 2001 SC2? Usumgal S-Series Tech 16 01-19-2010 03:56 PM
2001-2002 SC2 headlight assembly removal greencoupe02 S-Series General 1 08-11-2006 09:59 AM
1997 SC2 Composite Headlight Assembly avlonfrg S-Series General 1 05-21-2005 05:36 PM
2001 SC2 Headlight. between5and7 S-Series General 3 12-09-2004 03:18 AM
