Old 10-07-2020, 09:22 PM   #21
Astra08
Astra08 is on a distinguished road
Astra08's Avatar
2008 Astra XR
Default Re: Exhaust manifold/Upstream cat replacement
Originally Posted by Astra08 View Post
No problem. Studs emanating from the engine block, although I would typically use new on something like this, the nuts appeared in good shape so I reused them.
Before photo below, also a good idea to clean off the surface and mounting points with a wire wheel prior to reinstalling. I used a Dremel with a small rotary and cup shaped brush to do so.
Whoops, meant cylinder head.
Astra08 is offline   Reply With Quote
Old 10-08-2020, 12:53 PM   #22
ProOpel
ProOpel is on a distinguished road
Was that one of the UK designs above? They look darn good.
We still have emissions here, so I didn't want to deal with the CEL issue which I've encountered before with a freer flowing exhaust, so pretty much stock on this one.
It's the one from team2fast from Germany. It has a 200 sport cat in it. Hopefully it will fit right.
The other one you are referring to is from John Ashley's and that's nice too but no figures on HP improvement. It's a catless manifold but he suggested to weld a cat after the flex pipe.
08' Astra XE 5dr
5 spd manual
team2fast 200 sportcat
Autolite XP5224 spark plugs
GM valve cover/PCV (55564395)
OPC body work (wip)
ProOpel is offline   Reply With Quote
Old 10-08-2020, 07:01 PM   #23
Astra08
Astra08's Avatar
2008 Astra XR
Well, good luck. Be sure to post up some pics when installed, it will no doubt look sweet!
Old 10-08-2020, 09:43 PM   #24
ProOpel
Will do man
08' Astra XE 5dr
5 spd manual
OPC body work (wip)
Old 10-09-2020, 07:25 PM   #25
ProOpel
I got the manifold! They dispatch it fast! It seems like a good quality product.
I'll see if I can put it this week. Probably will start another thread as to not hijack yours. Should do a tuning thread since this is what I'm after with my Astra.
08' Astra XE 5dr
5 spd manual
OPC body work (wip)
Old 10-16-2020, 07:42 PM   #26
Astra08
Astra08's Avatar
2008 Astra XR
Nice piece! What was the final cost with shipping?
Old 10-17-2020, 12:54 PM   #27
ProOpel
It was $522, but out of which 90 bucks were for expediting it to the US, otherwise it would have taken a few weeks. Got it here in 4 days.
08' Astra XE 5dr
5 spd manual
OPC body work (wip)
DIY Exhaust Manifold Replacement Concern TheSilverSaturn Astra Tech 12 09-16-2017 06:38 PM
2006 Vue V6 Bank1 O2 upstream replacement amdamgraham Vue Tech 7 10-27-2014 11:39 PM
Exhaust manifold gasket replacement mypoorsl2 S-Series Tech 5 08-19-2010 12:51 PM
Replacement exhaust manifold studs/nuts??? emr131 S-Series Tech 6 06-30-2010 10:11 PM
exhaust manifold replacement and pcm PACT Man S-Series Mods 2 02-17-2006 05:51 AM
