Old 05-09-2016, 11:21 AM   #1
bluesapphire08
bluesapphire08 is on a distinguished road
Default Error code P2138
I went to leave work yesterday and the check engine light came on and I noticed the accelerator wasnt working right. I hooked up my OBD2 scanner and it showed P2138 which is or a voltage discrepency in the Accelerator Position Sensor. I checked the contacts and cleaned them with contact cleaner just in case. I didnt notice any issues with the wiring but I didnt test voltages. My reader shows no throttle response until the pedal hits 45%.
Long story short it looks like the sensor might be bad, only problem is I cant find one anywhere. Does anyone know where I can find a new one?
Add to bluesapphire08's Reputation
Rate the quality of this post and help bluesapphire08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bluesapphire08 is offline   Reply With Quote
Old 05-09-2016, 06:14 PM   #2
AstraFasta
Default Re: Error code P2138
Don't assume that sensor is bad.
Some areas to research in post #18:
http://www.saturnfans.com/forums/sho...ghlight=112052
Old 05-10-2016, 07:26 AM   #3
bluesapphire08
Thumbs Up Re: Error code P2138
Thanks for the information. I took apart my fuse box and cleaned it real good with contact cleaner. I did noticed those small water droplets they mentioned on the rubber seals. Put it all back together and now my pedal works fine. CEL is still on (P2138 still) but hopefully it will go away after I drive it a bit. Thanks again!
Old 05-10-2016, 10:09 AM   #4
AstraFasta
After drying the box, the code took a few days of intermittent activity before disappearing permanently for me.
Now we need to find a way to prevent water from entering the box.
Were the clips to your cover tightly closed? Or was it apparently a failure of the rubber-like gasket? Or from somewhere else?
If it is the latter, maybe some type of rubber-silicone, non-conductive grease on the gasket would be helpful?
Old 05-10-2016, 06:53 PM   #5
bluesapphire08
The CEL went away on my drive to work. As for preventing moisture from getting in there again I thought about creating a barrier around the battery/fuse block area to keep water from splashing in there.
Old 11-24-2017, 08:18 AM   #6
maschinenbauer
maschinenbauer will become famous soon enough
maschinenbauer's Avatar
2008 Astra XE
I just got the CEL code P2138 the other day. It happened at the very end of a long road trip. 91,000 miles on my 5-speed XE. Suddenly the pedal was completely unresponsive until about half throttle, and full throttle felt like limp mode. It happened on the interstate The entire road trip was dry sunny weather.
I limped it to our destination, unpacked, and took it to a parts store to get the code read. The pedal issue was gone after starting it up again, but the code remained. Later that evening and a couple start-ups later, the CEL was gone. It's been a few days and it hasn't returned...hopefully just an isolated glitch?
'08 Astra XE 5-speed
'72 Chevrolet El Camino
'31 Ford Model A pickup
Add to maschinenbauer's Reputation
Rate the quality of this post and help maschinenbauer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-25-2017, 08:44 AM   #7
maschinenbauer
2008 Astra XE
Just happened again last night while idling in traffic, causing me to stall the engine. Once I got going again, I cycled the ignition on and off while coasting and the pedal went back to normal. Hasn't rained for a week, so there shouldn't be water anywhere. Is this something I can fix with a new throttle pedal assembly?
Old 11-25-2017, 08:48 PM   #8
FreedomSoftware
FreedomSoftware is on a distinguished road
2008 Astra XR
This was happening to me about 2-3 months ago. I was getting a code for throttle/ pedal correlation. I got whole new throttle position sensor and a new pedal for about $150 from a GM dealer. Install was quick and easy took about 10 minutes. Just a couple bolts and a plug. Might be worth a try.
Edit: Mine was a different code, but it still states its the same thing. Throttle position sensor. Added a few words.
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-Thule Roof Rack (and wind fairing)
-1.25" Lowered
-Windows Tint all around
-JVC Head unit
-Dual 12" Subs
Add to FreedomSoftware's Reputation
Rate the quality of this post and help FreedomSoftware reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FreedomSoftware is offline   Reply With Quote
Old 11-26-2017, 12:45 AM   #9
AstraFasta
The water slowly leaked into my box and no way that would evaporate as is sealed well...but not well enough. Check out my post above for some preliminary ideas...
Old 04-14-2018, 08:11 PM   #10
Chuck3gel
Chuck3gel is on a distinguished road
Maschinenbauer, Did you ever find a resolution to this? I just had the same thing happen to mine today. Once I shut off engine and restarted things were back to normal (other than CEL, which I reset). I expect I will see this again. Did you end up replacing the TPS or the pedal position sensor?
Thanks
Add to Chuck3gel's Reputation
Rate the quality of this post and help Chuck3gel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chuck3gel is offline   Reply With Quote
Old 09-12-2018, 09:54 AM   #11
FreedomSoftware
2008 Astra XR
Bumping this thread because this happened to me last night. I was on my way to my parents house when my throttle was barely working 45%+ the only time my car would do anything. I basically had to floor it get up to speed.
Weird thing is I replaced my pedal less than a year ago and its now doing the same thing. I'm going to check the fuse box for moisture and hope I can get replace the position sensor under warranty.
Edit: Shutting off the engine (**and pulling out the key**) worked with resetting it, but my pedal still feels off, like it needs calibrated or something. I also cleared the code in case it came back.
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-1.25" Lowered
-JVC Head unit
-Dual 12" Subs
Can't figure it out, Code P2138, P2122 07saturnion Ion Tech 2 06-01-2015 08:48 AM
08 VUE XR AWD engine code P0335 and P2138 mmmkkk 2008 Vue 3 02-01-2013 08:03 PM
P2138 Error Code RiversideAstra Astra Tech 2 07-18-2012 05:26 PM
Code P2138 08 Veu v8 AnxietyTrip 2008 Vue 5 06-26-2011 12:17 PM
Throttle down - P2138 error - aftermarket equipment cause? jimsz Ion Tech 2 04-09-2010 12:24 PM
