Old 10-04-2006, 12:52 AM   #1
charliep
charliep is on a distinguished road
Default 97 SL1 Needs 2 Cranks
My 97 Saturn SL1 always seems to need two cranks in order to start. Kind of like the first one primes the engine and the second one actually starts the engine. A single long crank will not work. Any explanation of why this is the case and how to fix it would be greatly appreciated. I just use regular in the car so I guess it could be the gas, but the car runs fine otherwise. Thanks.
Add to charliep's Reputation
Rate the quality of this post and help charliep reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
charliep is offline   Reply With Quote
Old 10-04-2006, 01:15 AM   #2
Pro_leonk
Pro_leonk is on a distinguished road
1997 SW2
Default Re: 97 SL1 Needs 2 Cranks
My 97 SW2 does the same. Appartenly the fuel pumps around that year werent that good. Usually needs 2-3 cranks till it starts? Usually when the engine is hot?
I am thinking about replacing the crank angle sensor, see if that helps.
Add to Pro_leonk's Reputation
Rate the quality of this post and help Pro_leonk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pro_leonk is offline   Reply With Quote
Old 10-04-2006, 03:37 AM   #3
eljefino
eljefino's Avatar
1995 SW1
There's a check valve that keeps the fuel lines from emptying into the tank when the car sits. This fails and is only fixed with a whole new pump.
Workaround is to turn the key on, wait a few seconds, then crank.
Add to eljefino's Reputation
Old 10-04-2006, 08:10 AM   #4
97coupe
97coupe is on a distinguished road
My daughters 97 SC2 was like that when she got it but when i finailly got around to changing the fuel filter it cured the problem.
Add to 97coupe's Reputation
Rate the quality of this post and help 97coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97coupe is offline   Reply With Quote
Old 10-04-2006, 11:10 AM   #5
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
Just turn the key on, wait until you hear the fuel pump stop priming, then crank it.
You can tell Linux is made by geeks.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
cranks but no start kandjj S-Series Tech 13 02-15-2008 06:31 AM
NO START!!!! 3 Cranks and then nothing HELP!!! bryanmckinlay Ion Tech 2 12-17-2007 02:57 PM
Cranks but doesn't start? Rapsack S-Series Tech 3 04-24-2007 08:46 PM
Cranks but will not start..Help please loverboyred L-Series Tech 1 03-15-2006 04:11 PM
Cranks for a while before starting... TIMSPEED S-Series Tech 13 01-27-2005 09:52 AM
