Old 08-18-2014, 03:12 PM   #1
aliensporebomb
aliensporebomb is on a distinguished road
Wrench Light bulb behind the Odometer burned out....
So, I know it's a huge pain to get a replacement bulb back there.
I wonder if an LED would make sense if I do decide to get that taken care of.
Anyone? Beuller? Beuller?
Add to aliensporebomb's Reputation
Rate the quality of this post and help aliensporebomb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aliensporebomb is offline   Reply With Quote
Old 08-18-2014, 08:05 PM   #2
pierrot
pierrot's Avatar
Default Re: Light bulb behind the Odometer burned out....
No, it really isn't. It's fairly easy. Remove the lower panel beneath the steering column. Remove the cluster bezel torx screws, pull out the bezel, and you have access to the instrument cluster mounting screws. You need to push the steering wheel height adjustment as low as possible to remove the cluster. Once the mounting screws are removed simply pull the cluster out. It's a plug-in unit. Be sure to remove the fuse for the air bags first to avoid accidental deployment.
I've replaced the odometer bulb and it is an LED. It's the only one on the whole instrument cluster.
280,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 08-19-2014, 04:53 AM   #3
Hmm, my '03 L300 odo bulb burned out after 10 years/80k miles. I found a different incandescent replacement since it was difficult to find an original. Most leds are fixed permanently like most of the indicators (ABS/airbag/oil/battery/seat belt/check engine) - not easily replaceable like the odo bulb.
Old 08-19-2014, 08:10 AM   #4
Russet
2002 L-Series 3.0L Sedan
Odd, I went to my local Volkswagon dealer and was able to order those bulbs? I also think your local GM dealer should be able to get those bulbs.
Add to Russet's Reputation
Old 08-19-2014, 12:01 PM   #5
pierrot
pierrot's Avatar
I was able to purchase my replacement odometer bulb two years ago through the local Chevrolet dealership. I was told there that this one was an LED, not incandescent. Nevertheless, it's the only style bulb of its kind on the instrument cluster.
Old 08-19-2014, 04:51 PM   #6
Russet
That is what I found odd when I ordered that bulb and the rest....but one is white the rest are blue.....go figure...
Old 08-19-2014, 07:51 PM   #7
pierrot
pierrot's Avatar
While you and I were able to find what we needed through our respective GM dealerships it's also possible that, in the region where our friend fdryer resides, his situation could've been otherwise. This may surprise both you and me, but there can always be differences in the supply line from one region to the next.
As for the color of the bases of the replacement cluster bulbs: apart from the odometer bulb, my originals were blue and the replacements have been an off-white, or beige color. FWIW, I don't concern myself much with the color of such things - and I'm not suggesting that you do - because manufacturers change those items for their own purposes after the factory lot has been used up. In this case it's merely cosmetic.
Old 08-20-2014, 01:12 PM   #8
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
The odometer bulb is not an LED. It is a regular incandescent bulb with an etched surface for even the light distribution. It is Saturn/GM part number 21019273. The same bulb was used for the odometer on the 3rd gen (2000-2002) S-Series. The part number for the other gauge cluster bulbs is 22695949.
Saturn parts are actually easier to obtain now since the demise of Saturn. You used to only be able to get Saturn parts from a Saturn dealership. Now you can go to any GM dealership that is a Saturn Authorized Service Center and order Saturn parts.
2007 Chevy Equinox LT 177K miles
Add to ruley73's Reputation
Old 08-20-2014, 07:43 PM   #9
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
A shortcut on removing the cluster. You don't need to completely remove the padded panel below the steering wheel. Just pull firmly on the top edge to release the spring catches. The bottom will just hinge down. This gives you access to the bottom bezel screws.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Orange DRL light bulb already burned out - warranty? If not, long life replacement? Threxx Aura General 12 07-01-2010 04:53 PM
Does a burned out Check engine bulb trigger the wrench? chevy57 L-Series Tech 2 02-23-2009 01:57 PM
Can a burned out light bulb cause other problems? StarLady S-Series Tech 5 06-24-2008 09:19 PM
Side Fender Bulb Burned Out Azrael_02 Aura General 3 03-16-2007 12:59 PM
Odometer Light Bulb JOHN RETTMER S-Series Tech 5 09-14-2003 02:42 PM
