Old 01-09-2006, 01:57 AM   #1
JS593
JS593 is on a distinguished road
JS593's Avatar
1992 SL1
Default Possible rack and pinion problem?
Well, i have been driving my satty with 2 bad lower ball joints, and what may seem like a loose (but not totally worn) tie rod end on the driver side. I recently replaced one of the lower ball joints (because they are so expensive up here, and strapped for cash, it had to wait a while.) but now i am very worried, whenever i hit a bump, or when i get ice slide (because some and most cars have wider center point, saturns sometimes dont stay in tread) i feel the sterring wheel jerk alot. and baecuase they dont know how to PLOW once and a while here.. it just builds up over time. When i hit the bump and come off it, it almost seems like my entire steering wheel has like a loose bearing, or something out of place. Am i on the right track of a rack and pinion system fault? or could it just be the tie rod end not holding the wheel good enough? Any input on this is appreciated. Thanks.
92 SL1 SOHC TBI
Custom intake
Alpine deck, speakers, amp
JBL Sub
Ultimate amp
Volometer gauge mounted in dash
Magnaflow exhaust
....DEAD.... Car towed away Jan 18 2007. RIP
Add to JS593's Reputation
Rate the quality of this post and help JS593 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JS593 is offline   Reply With Quote
Old 01-09-2006, 09:33 AM   #2
DukeCitySC2
DukeCitySC2 is on a distinguished road
DukeCitySC2's Avatar
2006 ION-2 Sedan
1993 SC2
Default Re: Possible rack and pinion problem?
Sounds like you should take the car to a professional and have it properly diagnosed. You can do the repairs he finds are necessary. Guessing what's wrong with steering systems may be fooling with your life.
Add to DukeCitySC2's Reputation
Rate the quality of this post and help DukeCitySC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DukeCitySC2 is offline   Reply With Quote
Old 01-09-2006, 09:44 AM   #3
JS593
JS593's Avatar
1992 SL1
Im not guessing with steering systems, because if it is rack and pinion system, i sell the car. If you dont know my situation with this car, then you wouldnt understand what kind of hell i have been through with it. I knew i should have kept my 1987 Chevy Caprice 350LT1
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Old 01-09-2006, 10:11 AM   #4
amazinghl
So, you still have one bad ball joing and one bad tie-rod on your car?
00 Insight 72mpg
Add to amazinghl's Reputation
Old 01-09-2006, 10:53 AM   #5
JS593
JS593's Avatar
1992 SL1
unfortunatly. Which one should i replace first? (considering there is pull on wheels, should i do the tie rod end then the lower ball joint?)
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Old 01-09-2006, 11:02 AM   #6
bldegle2
bldegle2 is on a distinguished road
obviously, you don't like your Saturn, and being short on cash for repairs, well..........
get rid of it, after you fix the steering, or not.
go get another 1987 Chevy Caprice 350LT1, my guess is that you will be mucho happier.........but poorer, not so good gas mileage, just to mention one.............
baldy
Add to bldegle2's Reputation
Rate the quality of this post and help bldegle2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bldegle2 is offline   Reply With Quote
Old 01-09-2006, 11:18 AM   #7
amazinghl
Sell the car for whatver you can, move on.
00 Insight 72mpg
Old 01-09-2006, 02:19 PM   #8
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
If you dont sell the car fix the tie rod end soon! I have had one fail on me - a heart stopping experience to suddenly loose all steering and come skidding to a stop because the wheel turned in. Brakes and steering are two things you dont want to put off for any reason.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 01-10-2006, 01:52 AM   #9
DukeCitySC2
2006 ION-2 Sedan
1993 SC2
Actually, I have followed your MPG thread, that's why I'm suggesting you take it to a pro. You would likely be money ahead to find out what the real problem is, instead of spending money on fixing something that isn't the real problem. On the other hand, it sounds in the MPG thread like your engine is not right, and it sounds like half your suspension is not right, so maybe you ought to just move on.
FWIW, I can't believe you'd move back to an LT1. I just got rid of one ('97 Camaro Z28). Price out an optronic distributor or a set of plug wires. $500 list price on the dizzy, $75 for the wires. Six hours to install them. And you'll need them!
Old 01-10-2006, 03:10 PM   #10
JS593
JS593's Avatar
1992 SL1
Considering ive already installed the parts (tie rod end and rear brake shoes) its kinda late to say sell it. and i need the car... cause i work delivery. I am now up to 31 MPG and rockin on. since i replaced the TB, everything seems to work 100% better. all i need it one more lower ball joint, and im good to go.
As for your comment bedegle2
"obviously, you don't like your Saturn"
Your so off there its not funny. I love my saturn... you maybe cant tell, but its just frusterating dealing with all the in between crap on the car that wasnt done in the first place. I mean, who doesnt do an oil change on a car for almost 6 years (100k) and doesnt do any maintenaance work on it... that i found out after i bought the car too... either way.. she's healthier then ever now.
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Old 01-10-2006, 05:48 PM   #11
bldegle2
hmm, could have fooled me, sorry, i just drew a conclusion based on the above comment.............
you can get a complete lower control arm for $42, and it comes with all the bushings and the ball joint, ready to install, and pretty easy to replace. there would be some shipping added to the $42, not much.
how much does a single ball joint cost????
100k without an oil change, wow.
baldy
Old 01-10-2006, 06:23 PM   #12
amazinghl
Then fix it.
Ebay is a good source for control arm and tie-rod.
That's where I got mine.
00 Insight 72mpg
Old 01-10-2006, 07:55 PM   #13
JS593
JS593's Avatar
1992 SL1
Then fix it.
I havent seen any for about a month now.. i looked a few days ago.
approx 149.99 CAD+ tax. I get them at 79.99 (cheapo with no grease nipple )
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Old 01-10-2006, 09:04 PM   #14
amazinghl
Maybe if you use the correct term you'll find things.
http://search.ebay.com//search/searc...tle=arm+saturn
Tie Rods are also for sale for cheap.
http://search.ebay.com//search/searc...tle=saturn+tie
00 Insight 72mpg
Old 01-11-2006, 05:16 PM   #15
JS593
JS593's Avatar
1992 SL1
After shipping quotes and price conversion, and duty's at the border, i would end up paying well more then i paid. Im happy. But i asked the seller before why he discontinued the saturn LBJ's, he said at the time there wasnt much demand for them. He has put them back up recently (within past couple weeks i suppose)
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Old 01-11-2006, 05:43 PM   #16
amazinghl
Where are you located?
You do realize arm_can is shipping from Canada, right?
00 Insight 72mpg
Old 01-11-2006, 05:53 PM   #17
JS593
JS593's Avatar
1992 SL1
yeah i do, he is in toronto, i am in Manitoba (one province away), he said the shipping on both of them was 25+ (each) and then there was some sort of bullcrap holding fee's. It came out to 245 by the time i was done. I got mine for 140 for both.
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Possible bad 95 Rack and Pinion Canyon S-Series Tech 18 09-08-2008 08:57 PM
rack and pinion Jeremy13 S-Series General 3 06-09-2008 02:30 PM
Rack and Pinion Problem 93slbb S-Series Tech 1 03-28-2007 10:15 PM
Rack & pinion Lafarga L-Series Tech 7 02-06-2006 06:15 PM
Rack and pinion problem? NEWLW300OWNR Ion General 3 02-16-2001 08:50 PM
