Old 07-29-2005, 11:26 AM   #1
fatherof5
fatherof5 is on a distinguished road
Default Stop the Blinking Coolant level light!
The light on the dashboard keeps blinking, even though there is plenty of coolant. The cap is new, and I changed the ECTS for another problem. Does anyone know how to stop the *&^% thing from blinking??
Add to fatherof5's Reputation
Rate the quality of this post and help fatherof5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fatherof5 is offline   Reply With Quote
Old 07-29-2005, 11:49 AM   #2
the_new_raceman
the_new_raceman is on a distinguished road
the_new_raceman's Avatar
Default Re: Stop the Blinking Coolant level light!
Add a lil more coolant..i did and mine went away
If you dont like the tires ur on...change em...now how does that apply to life??? think about it.
Add to the_new_raceman's Reputation
Rate the quality of this post and help the_new_raceman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_new_raceman is offline   Reply With Quote
Old 07-29-2005, 04:10 PM   #3
amazinghl
If you are SURE your coolant level is correct, just let it bink.
My saturn's light didn't stop blinking until 600+miles later.
Add to amazinghl's Reputation
Old 08-01-2005, 01:52 AM   #4
sierrap615
sierrap615's Avatar
did you check the connectior on the ECT?
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline   Reply With Quote
Old 08-01-2005, 07:59 AM   #5
Amp67
Amp67 is on a distinguished road
Amp67's Avatar
I had the same problem. It was a bad sensor in the coolant recovery tank. To rid myself of the annoying flashing light, I disconnected the sensor and shorted the connector. Flashing went away. Although, beware that if the car does develop a condition that causes coolant level to decrease (like a leak or head gasket going), you might not discover it until it is too late. Lately, I ended up buying a used recovery tank with sensor from a Saturn technician for $20. A new one is $48. You can probably also pick one up from junk yard, but stay away from a car with a blown head gaskets (oil in tank).
Hope that helps...
Amp
Add to Amp67's Reputation
Rate the quality of this post and help Amp67 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Amp67 is offline   Reply With Quote
Old 08-01-2005, 10:16 AM   #6
Saturn-Eh!
Saturn-Eh!'s Avatar
Just wanted to make sure that the level in the tank is above the "seam" that runs around the middle of the tank. though this is the official level line, I always fill an s-series about half an inch above. that way the light doesn't come on for a long time.
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline   Reply With Quote
Old 08-01-2005, 11:02 AM   #7
lukecp
lukecp is on a distinguished road
lukecp's Avatar
1997
Mine has been blinking for the last 22k miles. Where exactly is the sensor? I'd love to short the damn thing out, gets really annoying. Coolant has always been to the full mark and the car runs perfectly cool.
2000 Subaru Forester L, 5MT
FORMER: 1997 SL, 5MT
Add to lukecp's Reputation
Rate the quality of this post and help lukecp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lukecp is offline   Reply With Quote
Old 08-01-2005, 11:09 AM   #8
Amp67
Amp67's Avatar
You have to take the reservoir out to disconnect the sensor which is on the bottom, at least I had to. While you are at it, you might consider thoroughly cleaning and rinsing out the reservoir. Doing so might free up the sensor, so that it reads properly. Give it a shot. I had to remove the windshield washer reservoir and two coolant hoses first.
03 L300 low coolant level light on intermitently level is fine wooskie L-Series General 16 03-27-2010 05:26 PM
low coolant level light on but plenty of coolant in reservoir smote S-Series Tech 2 11-11-2008 01:04 PM
Coolant light and coolant level light flash after gunning it? FightingChance S-Series Tech 7 10-07-2006 11:03 PM
Coolant Temperature/Low Coolant Light blinking simultaneously mitya000 S-Series Tech 16 11-08-2004 10:55 PM
Security Light non-stop blinking RustyJCNC L-Series General 5 08-25-2004 01:53 PM
