Old 07-02-2019, 02:05 PM   #1
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
Default reprise on the old blower switch trick
hi Saturn sages- finally replaced the ac delco blower motor switch on the 01 L 100 . more involved than I thought took about 1hr. problem was the 3d speed was tricky and it would go to just air and no ac. other 3 speeds were perfect. thought it might be the blower resistor behind the glove compartment . heres what you have to do. pop off the bezel with a thin flat head screw driver and snap off the flasher plug from the back of it. put bezel aside. remove two side screws from radio , pull out antenna cable and put assembly on top of dash(should have enough wire. remove two screws from sides of heat/ac control module, be careful to not drop them down console as it will cause use of bad words. you will have to juggle and twist the module . disconnect the plug on the right side which controls air direction by squeezing tabs and wobbling the plug. squeeze the snap tabs on the plug to the speed switch and pull the plug. only one connector will be left on the left side. it is the cable to the left dial. turn the module upside down and release the holding tab with a thin screwdriver and slide off the cable end from the pull lever. the module is now free . it is a pain in the rump to un snap the tabs which hold the switch into the module . there are 3 of them and the thin screw driver will do it. it slides out from the back but the knob stays In the module. I didn't unsnap the clips holding the face plate on the module to reomove the old knob (whole thing is plastic and looked toofragile) . put it all back together and works perfectly. part cost 21 from carid delivered. also cost 6 f bombs in total. like it when the po guys win. regards bob f
Add to rfisher's Reputation
Rate the quality of this post and help rfisher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rfisher is offline   Reply With Quote
the old blower motor switch trick rfisher L-Series Tech 3 06-16-2019 07:42 AM
2004 Ion Blower Fan Switch ddemier7 Ion General 1 09-02-2016 08:06 PM
Blower Fan switch malfunction cola Vue Tech 2 05-08-2012 01:15 PM
Blower Control Switch t&m S-Series Tech 1 02-11-2010 02:05 PM
HAVC blower switch sebc S-Series Tech 1 11-14-2003 04:09 AM
