Old 06-29-2019, 02:49 PM   #1
Tyson
Tyson is a jewel in the roughTyson is a jewel in the roughTyson is a jewel in the rough
2002 L-Series 3.0L Sedan
Default Replace inlet water housing or “block fitting”
I replaced the “block fitting”. Otherwise known as the inlet water housing. If anyone needs help with this. It is on opposite side of engine block from thermostat of an l series . 2002 l300. The part # is 55351896. You’ll only be able to order it through eBay or a GM website. Just type in the part number in google and it’ll pop up. Make sure you order the o ring as well. There is no gasket for this part. It’s just metal to metal. Hope this helps anyone. It took me months to figure out what it was.
Add to Tyson's Reputation
Rate the quality of this post and help Tyson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tyson is offline   Reply With Quote
Block fitting for 2002 l300 Tyson L-Series Tech 1 06-22-2019 01:13 PM
Block fitting Tyson L-Series Tech 1 06-21-2019 07:29 PM
Oil in coolant-Need fitting size at engine block to bypass oil cooler on 3.0/L-81 DTMartin Vue Tech 3 12-12-2016 07:27 PM
Need thread spec for water outlet fitting (92 SL2 DOHC) jwawa S-Series Tech 5 06-11-2011 07:36 PM
Water pump housing Fergamis S-Series Tech 5 01-07-2011 11:01 AM
