Old 06-29-2019, 09:12 AM   #1
Tyson
Tyson is a jewel in the roughTyson is a jewel in the roughTyson is a jewel in the rough
2002 L-Series 3.0L Sedan
Default Ac recharge
Which ac recharge should I use for my 2002 l300? And how many cans do I need?
Tyson is offline   Reply With Quote
Old 07-01-2019, 05:37 PM   #2
Default Re: Ac recharge
Before throwing away money on refrigerant refilling................a leaking system that will leak new refrigerant, it's simply wiser to buy an inexpensive uv light and spend time looking for leaks. Every Saturn came with dye at factory assembly and remains permanently mixed in with pag oil. Remove either service caps and look - you're likely seeing greenish yellow dye along with oil seeping out. Dye will glow under uv light at night or in a darkened garage. If you don't spend the time looking for why refrigerant leaked out, you're just refilling a leaking system.
Find the source(s) of this leak and then decide on repairs. Most repairs are straight forward with a few precautions of using new O-rings. An evacuation is needed to remove air and moisture in a repaired system before refilling with refrigerant. Mechanical repairs are easier for diyers while using vacuum pump and gauges more difficult to perform unless familiar with refrigeration repairs. This part can be performed by ac repair shops. And please don't use sealer as all you'll do is create the largest repair bill possible. Sealer does more harm than good as diyers find out the hard way.
Old 07-02-2019, 02:47 PM   #3
Russet
Russet has a spectacular aura aboutRusset has a spectacular aura about
Have it test first then you'll know if there is a leak or just needs R134 recharge. But if there is a leak recharge will do you no good til you fix the leak or broken A/C line.
Old 07-02-2019, 05:31 PM   #4
Labeling in the engine bay should have refrigerant amount, 33.5ozs.
Recharge my ac Mysaturnbeater S-Series General 10 08-12-2018 01:29 PM
A/C Recharge AQuinn19 S-Series Tech 6 07-08-2010 08:17 AM
A/C recharge... OnDaGround S-Series Tech 2 04-22-2009 10:03 AM
Do you ever need to recharge A/C? latestgood S-Series Tech 5 05-21-2008 06:23 PM
AC/Recharge Zvolen S-Series Tech 6 07-25-2007 12:59 PM
