Old 06-21-2019, 07:08 PM   #1
Tyson
Tyson is a jewel in the roughTyson is a jewel in the roughTyson is a jewel in the rough
2002 L-Series 3.0L Sedan
Default Block fitting
I'm about to put a knew o ring in the block fitting. Does anyone know if there's a gasket as well or just the o ring?
Tyson is offline   Reply With Quote
Old 06-21-2019, 07:29 PM   #2
Default Re: Block fitting
Nope. nothing more. With metal to metal mating and a flexible seal for sealing against coolant leaks, a few things should be kept in mind when reassembling. Both surfaces are clean and free of corrosion, the groove for the seal should be free of corrosion and both metal parts that mate should be flat to allow the seal to work. Corrosion that builds up can interfere with mating surfaces leading to less than an ideal seal.
Oil in coolant-Need fitting size at engine block to bypass oil cooler on 3.0/L-81 DTMartin Vue Tech 3 12-12-2016 07:27 PM
What are the odds of fitting this on my SL? 1.9 sohc S-Series General 6 07-10-2012 11:00 AM
Fitting a '91 to a '99 exhaust hacker_dx S-Series Mods 2 07-20-2008 08:02 PM
2001/2002 block and block brace??? dragon370 S-Series Mods 11 03-21-2007 11:20 PM
fitting vue4u2nv Vue General 4 05-05-2003 01:46 PM
