Old 05-04-2017, 09:05 PM   #1
JLROhio
JLROhio is on a distinguished road
Default 2004 Saturn Vue - Will Not Shift into Reverse - Manual Transmission
As the subject says, my mom has a 2004 Saturn Vue that would not allow her to shift into Reverse the other day when she was out. It has a manual transmission with about 80k miles on it.
She states that all other gears work just fine but that when she tries to put it in Reverse, it will not go into gear - or in other words, will not allow her to move the shifter into the reverse gear - it's as though something is preventing her from pulling it all the way down into Reverse gear.
I've tried doing some searching for this issue but have not come up with anything definitive...the closest I got in my search was others discussing how a grommet/eyelet on the end of a shift cable link may be broken.
Figured I'd ask the community here for some possible reasons why someone would be physically prevented from shifting the knob into the reverse gear.
Thanks in advance.
Add to JLROhio's Reputation
Rate the quality of this post and help JLROhio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JLROhio is offline   Reply With Quote
Old 05-11-2017, 06:35 PM   #2
silvervue06
silvervue06 is on a distinguished road
Default Re: 2004 Saturn Vue - Will Not Shift into Reverse - Manual Transmission
It did happen to me once a couple of years ago on my 06 Vue.
It did turn out to be the the "Shift Adjuster" which is plastic.
The part seems to not last forever as it should.
It will wear out. I bought the part from a local GM dealership for $33.
Then I removed the old one, put the new one in.
Done.
I saved $250 as a local car service place quoted me.
It's easy to check by removing the stick shift console cover.
Check out this site:
http://www.instructables.com/id/Fixi...-a-Saturn-VUE/
Hope this helps.
Add to silvervue06's Reputation
Rate the quality of this post and help silvervue06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silvervue06 is offline   Reply With Quote
2004 Saturn Vue 4 manual transmission. Sadiaz7 Vue Tech 3 10-09-2013 10:34 PM
Manual Transmission shift button - no shift schreckman Outlook General 2 12-17-2012 12:48 PM
Saturn Vue 2005 - Hard to Shift Manual Transmission puertoricanpete Vue General 10 11-21-2012 12:44 PM
transmission shift to reverse late Montreal300 S-Series General 3 01-08-2012 07:58 PM
2000 Saturn L series V6 manual transmission stuck in reverse gord1725 L-Series Tech 3 01-11-2010 01:26 PM
