Old 09-12-2014, 02:02 PM   #1
Daox
Daox is on a distinguished road
Default Problem areas to look for when buying a 98 SL1
I'm looking at a 1998 SL1, 5 speed manual, 120k miles tonight. What are some common issues these cars have that I should look at? I know they tend to burn oil, but other than that I'm not sure what to look for besides the regular stuff like rust, tire condition, etc. Thanks!
Add to Daox's Reputation
Rate the quality of this post and help Daox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Daox is offline   Reply With Quote
Old 09-12-2014, 03:02 PM   #2
trottida
trottida's Avatar
Default Re: Problem areas to look for when buying a 98 SL1
I would include....
look for drivers side front subframe rust through, holes in the rear door sills, top motor mount condition (results in vibration/cabin noise), low operating temperature (gauge at 1/4 usually means stuck thermostat and/or faulty ECTS), front bearing play, condition of lower control arm bushings and ball joints and the state of the exhaust system (flexpipe and muffler seem to be first to go).
What part of the country are you located?
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 09-12-2014, 03:08 PM   #3
Daox
Thanks!
I'm in Wisconsin, so rust is definitely an issue to look for.
Old 09-12-2014, 06:00 PM   #4
KDulcimer
KDulcimer is on a distinguished road
Just so you know, these cars have polymer body panels, so if the panels look great and rust free, that's because they always look that way. The hood, roof, and trunk lid are metal, and occasionally do show a bit of rust.
The rusty areas you need to worry about are first, the front subframe, and second, the rear door sills. Door sill repair is a DIY; front subframe is about $100 for the part, plus about a day of labor (less if a mechanic is doing it).
Car should run right about 1500 RPM in 4th @ 30 and 2000 RPM in 5th @ 55. If it's much higher than that, the clutch could be going.
If the headlights are cloudy, replacements are about $75. Can be a bargaining chip.
5 speed SL1s are the best in terms of fuel economy. Should get 30 MPG around town and 40 on the highway.
SaturnFans helper map: http://bit.ly/1uDorVF
1998 SW2 & 2002 SL sold, but I still see them around!
Purchased automatic 1996 SW2 September 2018.
Add to KDulcimer's Reputation
Rate the quality of this post and help KDulcimer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KDulcimer is offline   Reply With Quote
Old 09-12-2014, 07:34 PM   #5
el diablo viejo
el diablo viejo's Avatar
1994 SW1
SL1s are also famous for cracked heads. Check for oil in coolant and coolant in oil, coolant additives, coolant leaks, and overheating
97 sl2 a/t 104 K
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-17-2014, 04:45 PM   #6
Daox
Thanks guys. I ended up passing on the one I saw. It just had too many issues. Still got my eye out for one though.
Gen 3 SC1 Problem Areas? ohioguy98 S-Series General 1 05-22-2014 11:28 PM
Thinking about buying an '04 Ion Level III sedan with a transmission problem... 1999_Saturn_SC2 Ion General 15 07-28-2011 06:46 PM
Problem areas to look at b4 warranty is up..? snowman04976 Vue Tech 5 04-28-2008 11:09 PM
Looking at late 90's SC/SC2's...problem areas? COramprat S-Series General 18 04-22-2006 01:30 AM
Too Many Topic Areas? John10 General Saturn Discussion 10 10-17-2002 12:04 PM
