Old 10-12-2011, 10:57 PM   #1
MattBarszcz
MattBarszcz is on a distinguished road
MattBarszcz's Avatar
2002 SL1
Default Drain Plug Gasket Size
Neither my coolant drain plug or transmission drain plugs have rubber o-rings on them. I know some on here suggest using them. Without taking them off my car, does anyone know the size of the o-ring? Is it the same M9 as the oil drain plug?
Add to MattBarszcz's Reputation
Rate the quality of this post and help MattBarszcz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MattBarszcz is offline   Reply With Quote
Old 10-12-2011, 11:29 PM   #2
Default Re: Drain Plug Gasket Size
The transmission and oil drain plugs will take the Dorman 97115 gasket. The oil plug is 12mm and the transmission is 14mm and the gasket will fit both. Parts store will have them.
There is an aluminum washer on the block drain bolt.
Old 10-12-2011, 11:30 PM   #3
MattBarszcz
2002 SL1
Awesome thanks OldNuc
Oil drain plug gasket bez S-Series Tech 8 03-09-2009 08:18 PM
oil drain plug size mwyatt Vue Tech 2 04-30-2008 09:03 AM
Oil drain plug gasket 93goldsl2 S-Series Tech 6 07-13-2007 11:24 PM
Oil Drain Plug Size 2006 3.5L WarnsVue06 Vue Tech 6 12-06-2006 05:07 PM
2.2L Vue oil drain plug size? McGarrett Vue General 6 10-12-2003 02:35 PM
