Old 02-18-2010, 10:45 PM   #1
ClosetGeek
ClosetGeek is on a distinguished road
Default 93' SC2 Rack & Pinion Steering replacement...
Hey all,
I'm trying to get my SC2 back on the road this weekend and to do that I need to put my re-manufactured rack & pinion steering unit in.
To do that I need to bleed the whole system or I void the warranty.
What I need to know is which hose is the pressure line and which one is the return, and which one goes in where in the steering unit.
I hope to get response to this soon so that I can get this in and installed this weekend.
Thanks in advance out there for everyone's help on this.
Matt
1993 Saturn SC2 - RIP
1994 Saturn SL2
1989 Volvo 240 Wagon (AKA - Da Tank)
1991 Volvo 240 Wagon - Currently Restoring
1998 Volvo V70 Wagon
2003 Honda Odyssey
Add to ClosetGeek's Reputation
Rate the quality of this post and help ClosetGeek reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ClosetGeek is offline   Reply With Quote
Old 02-19-2010, 12:24 PM   #2
MikeNW
MikeNW's Avatar
1997 SL
Default Re: 93' SC2 Rack & Pinion Steering replacement...
Can't see which hose goes where on my 97- no doubt someone can provide a picture from the FSM- sorry
08 Burgman 400
Add to MikeNW's Reputation
Old 02-19-2010, 04:00 PM   #3
bluesl2
bluesl2's Avatar
Just put a reference mark on one of the hoses, then remember which port on the rack you took it out of. I was trying to remember if the fittings on the rack are a different size so it would be impossible to put them in wrong, I'm not sure though.
Add to bluesl2's Reputation
Old 02-19-2010, 06:13 PM   #4
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
They are different-you can't put them on the wrong way.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 02-19-2010, 08:25 PM   #5
ClosetGeek
Ok, this is all great news, but it does not answer the other question as to which one is the pressure line and which one is the return line.
I'm asking this as the directions for refilling the rack has the return line flowing into a container till it is clear before reconnecting to the rack.
Any and all help here is always appreciated.
Thanks in advance,
Matt
1994 Saturn SL2
2003 Honda Odyssey
Old 02-19-2010, 10:23 PM   #6
The pressure line is the one with the metal crimping on the flex lines where they joint to metal lines.
Add to ssicarman's Reputation
Old 02-19-2010, 10:52 PM   #7
bluesl2
bluesl2's Avatar
Look between the intake manifold and the back of the power steering pump, see the rubber hose with hose clamp securing it to the pump, that's the return line.
Old 02-19-2010, 11:03 PM   #8
ClosetGeek
To everyone who gave me advice, thank you very much!
I'll let you all know how it goes tomorrow.
Thanks again!
Matt
1994 Saturn SL2
2003 Honda Odyssey
Old 02-20-2010, 06:28 PM   #9
ClosetGeek
Well needless to say the steering rack is back in the car and operational. The car is still on the jack stands as I still have to push in a new wheel bearing for my slightly used steering knuckle.
I tried following the manufacturers directions to bleed the rack and such, but it did not go very well. I wound up having fluid leaking out so I stopped and hooked up both hoses and tried it that way instead. It squealed at first until fluid started flowing but then all was well with the world.
As I'm typing here I realized what I did wrong, but as the directions did state, I could do what I finally wound up doing any way.
Once I get the drivers side knuckle back on and the car lowered, I'll remove some of the fluid as I put too much in.
Any ways, I'm done for now in more ways than one.
Thanks again to all that aided me in this endeavor.
Matt
1994 Saturn SL2
2003 Honda Odyssey
Possible bad 95 Rack and Pinion Canyon S-Series Tech 18 09-08-2008 08:57 PM
rack and pinion Jeremy13 S-Series General 3 06-09-2008 02:30 PM
Rack and Pinion Problem 93slbb S-Series Tech 1 03-28-2007 10:15 PM
Rack & pinion Lafarga L-Series Tech 7 02-06-2006 06:15 PM
Another Parts Compatibily Quest. Power Steering Rack and Pinion? Which years are... Fricken eh! S-Series Tech 16 09-04-2004 12:27 PM
