Old 06-28-2019, 11:45 AM   #1
Dsaturn
2001 L-Series 2.2L Sedan
Default Odd problem.
Today I got in my l200 to go to store. Would not shift out of park and no brake lights so I figured I would turn it off then back on to see if that helped. No luck, Go to next step to see if fuse blew. Fuse looked and tested good with test light and multimeter. put fuse back in no joy. Replaced with new fuse problem solved. Put old fuse back in everything is fine.
My guess is corrosion on connections of fuse or in fuse panel. Any thoughts on this?
https://www.infowars.com/
Add to Dsaturn's Reputation
Old 06-28-2019, 04:58 PM   #2
Default Re: Odd problem.
Does "everything is fine" mean that the brake lights are functioning normally along with being able to shift out of park? If so then what you've posited is a reasonable possibility. I had the stop light switch fail on me some months ago and that resulted in the Brake/Transmission Shift-Interlock solenoid not releasing and locking the gear selector in park. (Prior to replacing the switch I looked through and examined the fuse as well.) Food for thought...perhaps a future concern.
FWIW, I had to get the stop light switch from AutoZone. Since it was a non-stocking part it was ordered from their warehouse, but it came the next morning. That was very helpful. While not my preferred place to go for parts, what was sold to me works and was much less expensive than O'Reilly's.
I'm glad that you got the car going again without any additional expense involved!
321,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 06-28-2019, 07:53 PM   #3
Dsaturn
Yes lights work and it shifts out of park.
Problem: Weird no-start-shift lock problem vstringbassist Ion Tech 8 12-09-2012 01:55 AM
Acceleration problem...gets stuck...possibly transmission? Or a gas problem? Dingo Warrior S-Series General 34 03-29-2009 01:20 PM
Irratic temp guage problem & CC problem 98dingo S-Series Tech 14 07-19-2007 11:43 AM
i found out want was the lack of power problem and shifting problem gypsy35 S-Series General 4 01-06-2006 08:49 AM
'98 SC2 with coolant problem +unrelated clutch problem Kpendrgn S-Series Tech 11 07-12-2003 10:02 PM
