Old 06-05-2019, 04:52 PM   #1
Tim Rich, Sr
Tim Rich, Sr has a spectacular aura aboutTim Rich, Sr has a spectacular aura aboutTim Rich, Sr has a spectacular aura about
2005 VUE 3.5L
Wrench AC Fix
I have posted a year or so ago in re an AC intermittent problem. It finally quit completely, and we cut short a planned long trip because of it. Several AC shops wanted to evacuate and recharge.
After we got home, I went back to the forum and searched again for the problem and found several owners that had found a bad ground problem. I disconnected the battery and started measuring resistance. From the clutch relay in the fuse box I measured 8.7k ohms to ground (measures through the clutch coil to ground). I thought that might be too high but being a coil, I thought it might have small gauge wire. Then I unplugged the connector at the compressor and measured the resistance to ground--- < 4ohms. I sprayed contact cleaner in both sides of the plug and coated with silicone connector lube. Presto, the AC is working without a hesitation since. Thanks to the fellow members for the insight.
Add to Tim Rich, Sr's Reputation
Rate the quality of this post and help Tim Rich, Sr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tim Rich, Sr is offline   Reply With Quote
