Old 11-07-2011, 08:29 PM   #21
JessicaDenny13
JessicaDenny13 is on a distinguished road
JessicaDenny13's Avatar
Checkered Flag Re: 03 vue 3.0 pcv valve/breather box?
catch can is on and drive shaft is out. Lets see what kind of fuel mileage we can wrap up. We've been getting 32 mpg so far on 89 octane. 170k+ and still getting it.
JessicaDenny13 is offline   Reply With Quote
Old 11-07-2011, 11:09 PM   #22
ncinerate
ncinerate will become famous soon enoughncinerate will become famous soon enough
Default Re: 03 vue 3.0 pcv valve/breather box?
Waaaaait. What?
32mpg?
Downhill with a tailwind? How in the world are you pulling that off .
I've managed 27-28mpg on a reasonably longer trip but city/highway driving is easily putting my 3.0 closer to the lower 20's than the low 30's, lol.
I'm running an AWD with the rear drive still installed - is removal of that shaft THAT big of a mpg difference? I'd love to hear how you're pulling this crazy mpg off.
ncinerate is offline   Reply With Quote
Old 11-09-2011, 10:08 PM   #23
JessicaDenny13
Wrench Re: 03 vue 3.0 pcv valve/breather box?
We got high 20s too when it was stock. I use full synthetic 10w-30. Fresh timing belt, e3 spark plugs, stage 3 custom exhaust system, Cold air intake below headlight with ram air tube, aftermarket breather/oil catch can, and oh yeah, no rear drive shaft. I have been all through the motor, and replaced all the gaskets from the heads up. Also, I run some seafome through the small vacuum port on the left side of the throttle body that feeds vacuum to the breather box on the head. The seafome cleans the black crud out of the intake and combustion chambers. Funny thing though, when i pulled the drive shaft, I could turn the yoke on the rear diff by hand-with both tires on the ground. yikes. Don't know if it should behave this way or not. i will post pics soon. Keep that fuel filter changed!
Old 11-10-2011, 09:22 AM   #24
JessicaDenny13
i'm trying to upload some pics. It keeps saying "vBulletin Message
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error." Then when I do that, I get this - "vBulletin Message Invalid Post specified. If you followed a valid link, please notify the administrator." Right. Maybe I can upload to photo bucket or make a video and put it on you tube.
Old 11-10-2011, 09:26 AM   #25
JessicaDenny13
One of the things that I think helped my mileage, besides the intake and the exhaust, was changing the pto and rdm fluid over to royal purple synchromax.
Old 12-16-2011, 06:12 PM   #26
megatron
megatron is on a distinguished road
I think you might have just helped me solve what is wrong with my vue, can you email me the pics? nick.steph.bachert@gmail.com. Does the oil separator need to be replaced, or will a good cleaning work?
megatron is offline   Reply With Quote
Old 12-16-2011, 06:36 PM   #27
megatron
that oil separator is $99 from GM
Old 12-27-2011, 05:20 PM   #28
Heitz
Heitz is on a distinguished road
Engine is running very strong now! I did have to do an extended crank even after priming the pump 3 times. I attributed this to the non-return type fuel system. I have no leaks and the dipstick tube has a light suction at 1500 to 2000 rpm. New 5/8 breather tube re-routed over the intake as per the tsb. Also replace the small vacuum hose. Crankcase breather nipple was clogged solid. I also cleaned the inside out and made me an awesome gasket. Since I removed the oil puddling on the spark plugs, I believe we will have smoother cold starts now. Best thing of all is we don't have to worry about the oil leak and the smell! One thing I did find when I was looking around on ebay that I think we could benifit from was a cylinder type pcv catch can with a drain on the bottom. I think this in conjunction with the factory oil separator would keep most of the crank vent oil out of the intake. "Universal JDM 750ml oil catch reservoir tank can." Price is 11 bucks, shipping is 10$ I think it will look good next to the polished cold air intake. Thanks again for all the help! I will post some pictures as soon as i get a new usb cable for my girlfriends camera.
Did you end up cleaning the inside of the crank case vent system. Do you have any photos? I'm glad I found this site, I must be one of 10 in the country driving a 2.5 liter SAAB.
Heitz is offline   Reply With Quote
Old 01-09-2012, 01:25 AM   #29
JSTDV8
JSTDV8 has a spectacular aura aboutJSTDV8 has a spectacular aura about
2008 VUE 3.5L
2002 VUE 3.0L
that pipe to the thermostat is good aluminum and so is the bracket. We just replaced our thermostat and found that the guy before us had broken the bracket as well and they zip tied it. we took it all out and welded the braket back to the tube no problem.
JSTDV8 is offline   Reply With Quote
Old 02-26-2013, 07:36 AM   #30
mzombek
mzombek is on a distinguished road
Newbie here,
I know that this is an old thread, but I have a question that may be related to this. When checking my oil every 1000 miles, I have a light tan color of oil on the fill cap. I assume that it is the moisture in the crank case mixing with the oil vapors. I have no water in the motor oil and no leaks on the block. Why is this happening?
Thanks,
Mike
mzombek is offline   Reply With Quote
Old 02-26-2013, 08:25 AM   #31
Chazberry
Chazberry's Avatar
1995 SW2
Originally Posted by mzombek View Post
Newbie here,
See this post . . .
http://www.saturnfans.com/forums/sho...9&postcount=29
Old 02-23-2019, 08:42 AM   #32
m1super90
m1super90 will become famous soon enough
My separator unit has a second vacuum nipple. That flat area on the vent's body, directly to the left of where the bolt is drawn in this picture. That area's has a standard sized vacuum hose nipple and a vacuum line is attached to it. I've tried tracing that line back but it's difficult to see where it ends up.
Anyone know what this second vacuum line is for? I thought it might be for an actively controlled (open/close) crankcase ventilation system.
Originally Posted by far2grumpy View Post
Have you tried to open other PDF?
Perhaps one you've previously saved?
Lets try jpg - click on thumbnail ...
m1super90 is offline   Reply With Quote
2003, breather box, pcv, valve cover, vue
breather hose mjoekingz28 S-Series General 1 03-06-2011 01:02 PM
Put on new Air Breather, SES code 23 followed Dreamimage S-Series Tech 4 07-29-2007 04:09 PM
Breather Filters.... n_c_mail S-Series Mods 56 03-21-2007 10:36 PM
Oil breather filter. DeCaff2006 S-Series General 7 07-07-2006 09:45 PM
A crankcase breather... JDub99SL2 Mods and Performance 7 09-14-2003 11:10 AM
