Old 12-07-2018, 02:51 AM   #5701
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
Default Re: What did you do to your S-Series today...
Much better
1999 SL2 A4 -85k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 12-10-2018, 12:32 AM   #5702
NWSaturn247
Was running a Prestone drive around flush since I replaced the thermostat. The stat was a Stant, made in Germany so odds are good that it is factory original, 20 years old!
Did a couple distilled water flushes., then drained and added a gallon of Prestone universal concentrate and topped off with distilled water
Good to go, excellent heat.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 12-21-2018, 09:19 PM   #5703
NWSaturn247
Removed the spark plugs (AC Delco 41-627) and installed some NGK V- Power BKR5E-11 plugs. I see a valve cover gasket replacement in my future. I will do it in the Spring after a good piston soak procedure.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 12-23-2018, 07:42 PM   #5704
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Got rear drums and wheel cylinders replaced on both sides just in time for Christmas.
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
Add to jpags729's Reputation
Rate the quality of this post and help jpags729 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpags729 is offline   Reply With Quote
Old 12-23-2018, 08:07 PM   #5705
SaturnGirl02
SaturnGirl02 is on a distinguished road
SaturnGirl02's Avatar
2002 SC1
Today I began removing the engine from my S-Series Saturn to swap it with another body! Have a lot of work ahead! #TheThingsIDoForMySaturn
Add to SaturnGirl02's Reputation
Rate the quality of this post and help SaturnGirl02 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnGirl02 is offline   Reply With Quote
Old 12-25-2018, 05:20 PM   #5706
wizerdwolf
wizerdwolf is on a distinguished road
2001 SW2
I swapped my front turn signals for LEDs and bought a new flasher relay to prevent hyper flashing (I didn't feel like modifying the existing one).
While I'm sure people could easily find the correct parts on their own, I'll attach a picture showing the upgrade parts I used. Works flawlessly!
Add to wizerdwolf's Reputation
Rate the quality of this post and help wizerdwolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wizerdwolf is offline   Reply With Quote
Old 01-03-2019, 09:57 PM   #5707
NWSaturn247
Installed the dirt cheap fog lights I purchased on eBay.
Old ones, GE. New ones, mystery grab bag ROC
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 01-03-2019, 10:52 PM   #5708
Put an electric heater inside the car.
It is plugged into a switch controlled outlet.
Add to Waiex191's Reputation
Old 01-04-2019, 08:20 PM   #5709
bumpdraft
bumpdraft's Avatar
1998 SW2
Today, I finally checked my ignition for misfires.
...and found some.
Oil use is 1 oz per 100 miles with approximately 230,000 mi on engine
Add to bumpdraft's Reputation
Old 01-04-2019, 08:28 PM   #5710
NWSaturn247
Added about half a can of mos2 to the oil.
Day 2, fog bulbs still work
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 01-04-2019, 08:45 PM   #5711
buenafe
buenafe is on a distinguished road
1996 SL2
I reviewed YouTube videos on how to fix passenger door handle. I'm unable to open door from inside. .
Add to buenafe's Reputation
Rate the quality of this post and help buenafe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
buenafe is offline   Reply With Quote
Old 01-05-2019, 06:38 PM   #5712
bumpdraft
bumpdraft's Avatar
1998 SW2
Didnít need a scan tool to smell the raw gasoline
...and found some.
One year ago, there were no misfires: Note short term fuel trim.
Spare supplies on hand Iíll replace everything and worry about what part failed later...when itís warmer.
Old 01-05-2019, 06:51 PM   #5713
Signmaster
Popped in my hi mount brake light sockets and bulbs for the two that wouldn't work even with new bulbs. Got a few OEM sockets with bulbs, and some spares from Rock Auto.
Fixed a side marker light problem that was due to a crappy ground.
Put in the new battery to replace the one that lasted forever. I swore I would probably get rid of the car before another battery. But while getting ready to do it I realized that every time I think of the car as disposable, I don't get rid of it. But I did buy a cheap battery this time.... maybe in a few years I'll quit fixing or replacing things.
Signmaster is online now   Reply With Quote
Old 01-05-2019, 08:45 PM   #5714
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
Replaced a clutch with my brother on his 97 Sl2, tried replacing some slave cylinder fluid on my 95 SL2.
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Old 01-05-2019, 11:59 PM   #5715
tizan
tizan is on a distinguished road
Default Seat covers
Put on new seat covers on my 2001 SC1 front seats...The driver side seat has started flaking and breaking out.
Add to tizan's Reputation
Rate the quality of this post and help tizan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tizan is offline   Reply With Quote
Old 01-07-2019, 02:51 PM   #5716
bumpdraft
bumpdraft's Avatar
1998 SW2
Corrected the misfire condition by
Here are everybodyís favorite DOHC sparkplugs at about 37,000-miles use
I am not sure what the problem was. I just replaced everything and saved the used parts for l a t e r
Old 01-08-2019, 06:35 PM   #5717
NWSaturn247
Dissolved 2 Bar's Leaks Radiator Stop Leak Professional Strength Formula tabs in a can. Added to the reservoir. Took for a good drive. I believe this is the formulation added in TN
Part #HDC
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 01-08-2019, 07:48 PM   #5718
That is the same as the no longer available GM tablets used to treat DexCool disease. Quite effective.
Old 01-12-2019, 05:28 PM   #5719
jpags729
jpags729's Avatar
Decided to do an oil change today....and what a mess it became. This is the first oil change I've done on the car, but had a receipt from Valvoline that did the last one. Look what the jack wagons had in my car!
Added Penzoil 5w-30 full synthetic and a Motorcraft 910-S oil filter. Sounds great now. But all the trouble removing the splash guard and then having to get that messed up drain bolt out was nuts.
Went to the junkyard and grabbed a drain bolt from an 07 Ion and it fit. Also grabbed 2 brand new brake drums off it as well, as that was the only part of the brake hardware I hadn't yet purchased.
Ya win some you lose some I guess!
Current:
Previous:
Old 01-13-2019, 01:32 PM   #5720
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by jpags729 View Post
... Look what the jack wagons had in my car!
...and then having to get that messed up drain bolt out was nuts.
That could be a performance mod
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
