Old 08-14-2017, 06:09 PM   #1
hojcat
hojcat is on a distinguished road
Dizzy 2005 VUE Redline Overheating
I usually do in town and freeway driving in my car (Redline). It is a 3.5L, V6 with 129,000 miles. Three years in a row, while driving mountainous roads heading from Phoenix AZ to CA and NV in July, the car overheated and it would not shift into overdrive. Twice it blew out transmission fluid under the hood. The first time it happened in 2015 and the ODB codes were P0741 and P0742. I let it cool off and it drove fine as long as I did not exceed fifty to fifty five mph.
In 2016 I realized what was happening and so I lowered my speed and continued my journey.
July 2017, the same scenario occurred as in 2015. This time I let it cool off, returned home and rented a car. I did not record the ODB code as it reset itself before I reached home.
Sorry about the long background story.
My mechanic drove the heck out of it and could not get it to throw the P0751 or P0752 codes. However, it did throw the P0420 and P0430 codes. This has not happened before or since. He topped of the transmission fluid at that time.
I took it to an auto electric shop and was told that they could not diagnose the problem unless it threw the codes in the repair bay. It only happens climbing hills in the Sonoran desert in July!
As a last resort, I went to the GM dealer. They started telling me that it is most likely my transmission... SO I LEFT!!! It never, ever slips, has any shifting problems or other transmission issues. Only the three aforementioned times on the road trips in July.
I was driving in town this week and now the car overheated, throwing a P2555 code. It was then that I discovered that only one of the two cooling fans is functioning (the main fan on the left side). The fan on the right side does not kick at all, even when the air conditioner is running.
Maybe this has been the problem all along, I do not know.
Finally my question: Are there any tests I can do to determine if the fan motor is burned out before tearing the front of my car apart to replace it? I checked the fuses and they look good.
Any ideas? Thanks!
Add to hojcat's Reputation
Rate the quality of this post and help hojcat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hojcat is offline   Reply With Quote
Old 08-14-2017, 08:27 PM   #2
billysvue
Default Re: 2005 VUE Redline Overheating
Has the trans ever had new fluid other than toppping off?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 08-14-2017, 10:11 PM   #3
hojcat
Yes, it was flushed at 100,000 miles per the maintenance schedule. The fluid is a little dirty but has a pinkish tint.
Old 08-14-2017, 10:19 PM   #4
billysvue
Every 25 thousand, it's needed . It was abused if it only got it @ 100 k.. Get a trans cooler after a couple drain/fills.
THe factory maintenance schedule is ferkakta.. THese trans' can overheat, as you've found out.. WHen that happens, you bake all the life out of the fluid.........
DW1 Honda Fluid, please.
Done the Tbelt?
'17 Suby Forester
Old 08-19-2017, 12:19 PM   #5
hojcat
Thumbs Up Re: 2005 VUE Redline Overheating
Yes, the timing chain was replaced 2 yrs ago.
Old 08-19-2017, 01:40 PM   #6
Originally Posted by hojcat View Post
.............. I discovered that only one of the two cooling fans is functioning (the main fan on the left side). The fan on the right side does not kick at all, even when the air conditioner is running. Maybe this has been the problem all along, I do not know. .... Are there any tests I can do to determine if the fan motor is burned out before tearing the front of my car apart to replace it? I checked the fuses and they look good.
Any ideas? Thanks!
Both cooling fans should be running when ac is turned on. Does ac cool when used? My two fans run together for low, medium and high speeds whether for engine cooling or ac use. With that in mind, I would examine the non operating fan to see if its stuck, carefully. With ignition off/cool engine, manually turn the fan blade by hand or use a stick. If free to spin, check for a blown fuse - fans may be labeled FAN 1, FAN 2. Pull fuses too verify them. If fuses are good, you can test the fan by connecting it directly to the battery.
Old 08-19-2017, 02:37 PM   #7
billysvue
INteresting trick for an engine that doesn't have a chain.
'17 Suby Forester
Old 08-10-2018, 06:18 PM   #8
hojcat
UPDATE - August 10th 2018:
Sorry, I haven't logged in here for a year. One of the fans was frozen. I found a youtube video where the guy showed how to lightly tap the fan at the base. I hit it several times and it started running again. I did end up having to have the transmission rebuilt. That solved my transmission issue of not shifting into overdrive on the freeway.
However, I still have the overheating problem. I finally took it to a shop last week and was informed that I needed a new water pump....This included flushing the cooling system and replacing the thermostat. Then the guy up-sold me radiator hoses (that I don't think I needed), a belt that runs the water pump around the water pump, alternator, etc. (this belt was replaced 3 years ago), and a harmonic balancer (that I didn't approve to have replaced beforehand). $1700. later, I have the same overheating issue.
The overflow reservoir appears to have mostly water in it with some scum floating at the top. The receipt indicates that 1 gallon of coolant was put in. I found that 2 gallons should have been put in for a Vue Redline 3.5L V6.
I know that I was totally ripped off by this garage. I am taking it back in today to try and get a resolution.
The gauge usually sits at the quarter mark. Now it is always at the middle and above. Does anyone else have the gauge at the 1/2 way mark in normal city driving?
Old 08-10-2018, 10:51 PM   #9
atikovi
Mine will point straight up in stop and go driving, and a little to the left of that that on the highway.
Add to atikovi's Reputation
4 Ron my 2005 Redline? 4minc Ion Red Line 2 09-23-2014 11:25 AM
2005 redline value vueredline0504 Vue Red Line 4 11-10-2012 12:00 PM
2005 VUE Redline vs 2009 VUE Redline SHMOKE Vue Red Line 27 03-22-2009 11:19 AM
2005 Redline for sale! snuffyRL Classifieds 0 01-20-2006 09:00 PM
Changes 2005 Redline? Genesisbreed Ion General 2 03-19-2005 02:28 AM
