Old 03-16-2014, 12:38 PM   #1
1bignordic
1bignordic has a spectacular aura about1bignordic has a spectacular aura about
1998 SW2
Default Summer Project:1.9 Engine Rebuild
I found a good rebuildable used 1.9L twin cam engine for $150. It runs good, just uses excessive oil. I'm thinking about purchasing it and rebuilding it over the summer. I've never rebuilt an engine before, its on my bucket list! lol...I'm very detail oriented, so I want to do an awesome job, any input is greatly appreciated!
Add to 1bignordic's Reputation
Rate the quality of this post and help 1bignordic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1bignordic is offline   Reply With Quote
Old 03-16-2014, 02:11 PM   #2
mrriden
mrriden is on a distinguished road
mrriden's Avatar
2002 SL1
Default Re: Summer Project:1.9 Engine Rebuild
Read as much as you can before starting with the purpose of knowing what you are equipped to do and what you're going to have to hand off for a machine shop to do for you. Do you own mics, calipers or snap gauges? Might have to send parts off to be measured if you don't. Access to special tools? Can they be rented locally? The average guy probably has tools enough to to assembly work but you should consider when it is better / cost effective to hand some components off for inspection / reworking. Then you can reassemble the nice shiny new bits together in your garage. Not knowing what's in your shop makes it hard to know. Here's one bit of advice. If you have a hone toss it directly into the trash and ignore anyone who advises you to use one.
http://www.snowvalley.20m.com/bikes/dnthone.htm
'02 SC2 'The Schnoot'
'94 SL2 'Beauty' (R.I.P.)
'02 SL1 'Silver Lining'
Add to mrriden's Reputation
Rate the quality of this post and help mrriden reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrriden is offline   Reply With Quote
Old 03-16-2014, 04:17 PM   #3
CZECHLAGER
CZECHLAGER has a spectacular aura aboutCZECHLAGER has a spectacular aura about
2001 SL2
1995 SW1
Hello, To stop the oil issue you have to drill six oil return holes in the oil control ring lan/grove if your still able to use the stock pistons. There is a Youtube video on how to do that. If you want new standard size piston or need to bore the block for over sized pistons they already have the oil control holes in them. Rick
Add to CZECHLAGER's Reputation
Rate the quality of this post and help CZECHLAGER reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CZECHLAGER is offline   Reply With Quote
Old 03-17-2014, 01:00 AM   #4
hholbein
Check out DoSumpthin 's Youtube channel. He did a rebuild of a DOHC engine and there are some videos of drilling oil holes and the timing chain replacement.
Add to hholbein's Reputation
Old 03-17-2014, 11:55 AM   #5
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
Forged internals.
Turbo.
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 03-17-2014, 02:29 PM   #6
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
Originally Posted by mrriden View Post
Thanks for sharing that. Twas a good read.
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Clearfield":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
1993 White SW2 5spd "Steve": 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Thinking about doing an engine rebuild this summer (pricing?) BobtheTechguy S-Series Tech 16 01-31-2013 10:53 AM
My summer L project... huyroy L-Series General 3 09-24-2012 12:48 PM
My next engine project destineers S-Series Tech 0 04-16-2011 03:35 PM
Updated rebuild project hAnNibAl_H S-Series Mods 8 06-18-2007 12:17 AM
Seeking advice on engine rebuild (Subaru.. and rebuild done) Scyan Miscellaneous Tech 8 06-13-2003 09:38 AM
