Old 03-15-2012, 05:29 PM   #21
madpogue
1996 SW2
Default Re: 2001 sc1 performance
Well I'll be dipped (no pun intended); I thought they were fiberglass, like they used to be.
Add to madpogue's Reputation
Old 03-16-2012, 09:01 AM   #22
Recycled Saturn
Recycled Saturn has a spectacular aura aboutRecycled Saturn has a spectacular aura aboutRecycled Saturn has a spectacular aura about
Recycled Saturn's Avatar
My go fast mod, more GM plastic
1998 SL2-AMR Strut Bar, AEM CAI, and 119,XXX
Add to Recycled Saturn's Reputation
Rate the quality of this post and help Recycled Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Recycled Saturn is offline   Reply With Quote
Old 03-17-2012, 04:43 PM   #23
bobyjones
bobyjones is on a distinguished road
Originally Posted by azrocketman View Post
Oh yes it is (and the body definitely is not metal)!
"Technically, all Corvettes since 1973 have used SMC body panels, but the material composition has changed dramatically, featuring less traditional fiberglass and more lightweight plastic. The early SMC material created parts that were stronger and more rigid, but more brittle. As SMC technology and production experience evolved, Corvette engineers were able to alter the material composition and the body parts' specifications in order to trim the car's curb weight--an endeavor that was certainly welcomed though the later C3 years, as engine output kept eroding. Mostly, that meant making thinner body panels, because SMC was denser and stronger than conventional fiberglass.
The assembly-plant changeover from St. Louis to Bowling Green in 1981 brought a switch to a more plastic-infused formula for the SMC body panels. Published figures vary, so without the capability to weigh both factory-stock '80 and '81 models, it's difficult to provide an accurate comparison of the weight differences between traditional fiberglass and SMC-bodied cars. From the numbers we researched, it appears the '81s were about 100 pounds lighter than their '80 counterparts. That's not all attributable to the SMC bodywork, however, since the change to a fiberglass mono-leaf rear spring for '81 accounted for about a 35-pound reduction. Nevertheless, newly formulated body panels helped lighten the Corvette--and it was the same basic formula used throughout the C4 generation.
Excerpted from the source below:
Read more: http://www.vetteweb.com/tech/vemp_11...#ixzz1pDiuBhLF
so wait corvetts are actually saturns in disguise?
Add to bobyjones's Reputation
Rate the quality of this post and help bobyjones reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobyjones is offline   Reply With Quote
Old 03-17-2012, 04:47 PM   #24
bobyjones
http://www.youtube.com/watch?v=XWYyUdruQK4
Old 03-19-2012, 11:20 AM   #25
azrocketman
azrocketman is on a distinguished road
azrocketman's Avatar
1997 SL1
It's a simple modification. You remove the the gas cap from the Saturn and drive the Corvette underneath. You then throw away the gas cap from the Saturn.
Steve
Add to azrocketman's Reputation
Rate the quality of this post and help azrocketman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
azrocketman is offline   Reply With Quote
Old 03-19-2012, 05:18 PM   #26
JohnS_98
JohnS_98 is on a distinguished road
JohnS_98's Avatar
Originally Posted by cloud819 View Post
These are my "I need to go faster" mods.
More pictures of the Lotus please! That thing is sweet!
Add to JohnS_98's Reputation
Rate the quality of this post and help JohnS_98 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JohnS_98 is offline   Reply With Quote
Old 03-19-2012, 06:51 PM   #27
cloud819
cloud819 will become famous soon enough
cloud819's Avatar
Hopefully know one uses 56K anymore.
Add to cloud819's Reputation
Rate the quality of this post and help cloud819 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cloud819 is offline   Reply With Quote
Old 03-19-2012, 08:09 PM   #28
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
That is one fine car and supermodel
1999 SL2 A4 -85k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 03-20-2012, 08:11 PM   #29
azrocketman
1997 SL1
The engine on this car ran about two minutes without any oil and ran without obvious distress for about a minute. I understand that the engine was at high idle and not loaded but how do most folks we read about in this forum manage to blow up their engines? Are they so dumb that they continue to operate the cars with almost no oil and the oil pressure light on? If so, there should be a law about automotive cruelty and these folks are sentenced to bicycles for 90 days.
Also, it looked like the catastrophic failure was at the right side of the engine. Did the oil pump seize and grenade the timing cover?
Steve
Old 04-01-2012, 12:50 PM   #30
bobyjones
saturns sc1s are sooo fast! they can barely beat a v6 pusstang in a race
http://www.youtube.com/watch?NR=1&fe...&v=dENhMTLz314
oh and wait compare that to the whopping the sl2 gave this other v6 pusstang
http://www.youtube.com/watch?v=STjnBaZiUrI
Old 04-01-2012, 04:43 PM   #31
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
DOHC S-Series... slightly faster than many other slow cars since 1991.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 04-02-2012, 11:44 AM   #32
ThDude
ThDude is on a distinguished road
ThDude's Avatar
1993 SL1
like winnning the special olympics of cars.
1998 saturn sc2, 175,000 miles.
1993 saturn SL1 sedan, at least 560,000 miles before a cracked cylender head blew.
1994 nissan 300zx t top, 90k miles. currently restoring.
Add to ThDude's Reputation
Rate the quality of this post and help ThDude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ThDude is offline   Reply With Quote
Old 04-03-2012, 12:01 AM   #33
bobyjones
stickers are aero mods, right?
Old 04-03-2012, 12:02 AM   #34
bobyjones
i like the 12 mufflers, one per valve
Old 04-04-2012, 01:47 PM   #35
swansong
swansong is on a distinguished road
2000 SC2
Seriously bobyjones, you need to quit trolling here. You never add anything useful or positive to any thread and bump things that are days, weeks, or years old. I think a ban would be appropriate, or at least GTFO.
Mine - 2002 Ford Focus SVT, 127k, Sonic Blue
Was mine - 2002 SL1, Auto, Cranberry, bought at a neglected 110k, sold at 125k
Wife's - 2000 SC2, Auto, 116k, Red, bought at a pampered 57k
Add to swansong's Reputation
Rate the quality of this post and help swansong reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
swansong is offline   Reply With Quote
Old 04-04-2012, 02:31 PM   #36
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
Mmm, the elusive 24v head. Where ever did you find it?
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 04-04-2012, 09:04 PM   #37
Tofutti
Tofutti is on a distinguished road
2002 SL
1994 SW2
install 600hp nos Stickerz all over your car, and your sc1 will turn into a rocket ship and fly to another galaxy! top speed of 104mph!
Oh come on now. My '99 SC1 is not great by any means and is totally stock and neglected but will at least bury the needle (at 110mph) and gain another 800 RPM after that... even WITHOUT the stickers!
..Holy crap. I should add stickers.... hmm.. lol
Add to Tofutti's Reputation
Rate the quality of this post and help Tofutti reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tofutti is offline   Reply With Quote
Old 04-15-2012, 01:46 AM   #38
bobyjones
Attention Re: 2001 sc1 performance
people cant take saturn jokes? or ricer jokes? what gives? is this a joke free society? how lame!
Old 04-15-2012, 05:41 PM   #39
AlexofNazareth
2002 SL1
2006 VUE Red Line
Go crawl back under the rock you came from
'06 Vue RL
2001 SL2: Engine noises and staggered performance Dudds S-Series Tech 0 08-30-2010 07:01 PM
2001 L300 Performance Parts? sixseriescsi L-Series General 31 01-20-2009 02:29 PM
2001 SL1---need some performance tips Yann S-Series Mods 5 10-14-2007 01:28 PM
WTB: any performance parts for a 2001 sc1 juspay4speed Classifieds 9 02-06-2006 09:10 PM
2001 Saturn Sc2 Performance Throttle Body blueraSCeR Mods and Performance 6 04-23-2004 04:17 PM
