Old 05-04-2013, 08:36 PM   #1
rockhead
rockhead is on a distinguished road
Default a/c low pressure hose
Just had my a/c serviced and was told and shown the leaky low pressure hose. I want to replace the hose my self and they take it back to have the system refilled. Does anyone know the part number. Rockauto has a couple hoses listed and I am having trouble telling which one I need. Also when I replace the hose is the anything special to do besides replacing the hose and the o-rings>
Add to rockhead's Reputation
Rate the quality of this post and help rockhead reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rockhead is offline   Reply With Quote
Old 05-04-2013, 10:10 PM   #2
Default Re: a/c low pressure hose
Year, model, manual, auto? The low pressure line can be described as low side/suction hose. Tried finding OEM numbers from GMpartsonline, http://parts.nalleygmc.com/, calling your local GM dealer, ackits.com?
When a line is replaced, its presumed refrigerant either leaked out or removed by a shop for recycling (EPA regulations), to prevent an unexpected high pressure discharge when disconnecting any line. Once removed, the replacement hose O-ring is lubed with R12 mineral oil (or drug store mineral oil) before tightening fittings. No PAG oil for O-ring lube. The compressor side uses a flat seal, not O-ring. If you substitute, you risk any leak that may result from using incorrect parts. Check the seal and O-ring removed from the old line and use to search for a replacement kit sold over the counter, search online or visit GM for parts. Once assembled, either continue with evacuating this repaired system with your equipment or have an a/c shop perform the rest of the a/c work.
Old 05-04-2013, 11:33 PM   #3
rockhead
2000 sl2 auto.
According to this diagram I need Part# 24 which is not listed for sale. Any one know a good place to buy this?
Old 05-04-2013, 11:42 PM   #4
rockhead
I guess I can not post url's
Old 05-06-2013, 10:32 AM   #5
rockhead
bump. Has anyone changed this hose that can confirm the part # or where you bought it.
Old 05-06-2013, 01:53 PM   #6
Posting piecemeal info just prolongs threads. Perhaps if you consolidate info more concisely no one will have to read every post. As to url's, the simple way around for new members is to put spaces in a few places - most here know to copy and paste url's without the spaces to find correct links. New members are restricted to (prevent spammers) until a number of posts are made and determined to be genuine posts and not blatant ads.
Can't find A/C low pressure hose. yosemitepaul S-Series Tech 13 06-19-2012 02:14 PM
low pressure ac hose mmtphoto S-Series Tech 15 04-13-2011 11:05 AM
anyone able to find pressure hose???? mygfdrivesavue Vue General 2 03-24-2011 02:59 PM
which is the high pressure P/S hose? kimpaw S-Series Tech 1 02-05-2011 06:37 PM
A/C low pressure hose... bxxpeace S-Series Tech 13 09-01-2010 05:46 PM
